CLB question - how do you know if installed?
Old May 1, 2005 | 10:00 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Default CLB question - how do you know if installed?
Bought a car from forum member here and he said the car was in the dlrship to have the CLB fixed.. however, I told him they probably just reflashed the ecu.. but he wasn't sure if that was all. So when I get the car how can I tell if the car had the clb or not? And also a good website i can get it from if it doesn't? Thanks!
Old May 1, 2005 | 11:00 PM
rickko's Avatar
rickko
One way is to take off gently from a stop sign/signal, watch your dash for the 1-4 light (yellowish) to appear. At that moment, try to shift to second. If you do, it IS installed. If you end up in 4th. It ISN'T installed.
Here are two good links:
http://forums.corvetteforum.com/show....php?t=1015483
http://www.ls1howto.com/index.php?article=24
I waited to install mine when I disassembled the dash/console to put in a Hurst shifter. Made it a bit easier with the console part of the dash out of the way.
..rickko..
Old May 1, 2005 | 11:06 PM
DDSLT5's Avatar
DDSLT5
To tell if you have the CLB, simply try to rotate your steering wheel with the engine off, key out of ignition. If the column locks, you don't have the bypass. If you can turn the wheel freely, the CLB is installed.
www.thunderracing.com is the site to buy the CLB
The call it a CLS - here is the page: http://www.thunderracing.com/catalog...d=220&pcid=156
Old May 1, 2005 | 11:12 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
Hah thanks.. I knew that was for the CAGS bypass which is already installed however I will wait till i see the car before i order the clb .. are the clbs all the same and same price?
Old May 1, 2005 | 11:18 PM
rickko's Avatar
rickko
Oops! Post deleted. Sorry about my brain-f*#t.
..rickko..
Old May 1, 2005 | 11:22 PM
coast7's Avatar
coast7
Thunder Racing and Corvettes of Houston are two of the trusted vendors...about $50...many how-to posts here...do a search...print one out that has pictures...and keep it with you as you are working...
good luck
Old May 1, 2005 | 11:26 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
rickko no problem here, you were just trying to help a "brother" out! and ty for the post coast7 I saw the one on corvettes of houston.
Old May 1, 2005 | 11:46 PM
DDSLT5's Avatar
DDSLT5
..rickko..
No problem - I'll remove all remnants of it!
Old May 2, 2005 | 12:13 AM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
I've put the one from Corvettes of Houston on my 98. Was a simple install and no more worrying.
Old May 2, 2005 | 12:16 AM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
Easy install and worth every penny.
column lock
Old May 2, 2005 | 12:54 AM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
So when car is off and key is out, pull up e brake and have her in 1st (as thats how i keep my car parked when off) and then turn my wheel either right or left and then back the opposite way.. if it doesn;t lock to where you CAN'T turn it then it is installed if not ill be ordering 1 asap Do i got it?
Old May 2, 2005 | 01:00 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
That's pretty much it. If you can move the wheel and not feel it lock, then you have the CLB installed.
To CLB question - how do you know if installed?
