C5 Convertible noise
Old May 2, 2005 | 07:09 AM
HummelCraigB's Avatar
HummelCraigB
4th Gear
Default C5 Convertible noise
I have a 2000 convertible with the ususal noise problem. I replaced the tires (Pilot run flat) with good results but now that they are wearing the sound is coming back.
I did the frost king and the fiberglass in the wheel well. some reduction.
Questions. Is the B-quiet product worth doing?
Is a trunk partition worth the expense?
Some of the noise is through the rag top. is there Anything for that grief?
Any other suggestions.
Craig
HummelCraigB@aol.com
Old May 2, 2005 | 07:41 AM
WKMCD's Avatar
WKMCD
Partition is definitely worth it. Frost king and partition and it's a much nicer ride even with headers/cats and Corsa Pace car exhahust.
Old May 2, 2005 | 08:37 AM
Jeffyvette's Avatar
Jeffyvette
Turn up the radio.
Jeffy'
Old May 2, 2005 | 10:35 AM
ronwc's Avatar
ronwc
I bought the $99 partition from Ecklers and it made a big noise reduction difference on mine -
Old May 2, 2005 | 10:39 AM
427C62013A's Avatar
427C62013A
Craig
You did the frost king mod and still have noise? Reason I ask is I just did mine and it made a huge difference using the kit from Exotic Vette.
My road noise is so much lower now.
Old May 2, 2005 | 11:28 AM
rickko's Avatar
rickko
Your post makes perfect sense, "...now that they are wearing the sound is coming back..."
The various recommendations above are all helpful but the problem you are facing lies with the fact the noise you are now hearing comes from road noise being amplified inside of the tire then on through the wheel, suspension system, frame, and anything connected to it which eventually causes the resonation in the car itself.
All the methods above do a great job on eliminating exterior sounds created from the tire running over a surface but do nothing for the noise that occurs inside the tire then transmitted through the vehicle internally.
The only way you can reduce that interior noise resonation is to change tires.
The EMT sidewalls are noisy due to their construction. The EMTs on the C6's have been redesigned (100 mile range at zero pressure vice 200 mile range on '04's and older. Goodyear changed the sidewall construction and used a slightly softer compound for '05).
So, the new EMTs are definitely quieter and non-EMTs even quieter still.
..rickko..
Old May 2, 2005 | 03:55 PM
2003vert's Avatar
2003vert
All of the above Info is good. but if you have not done the trunk and bulk head you really need to do that. The product that I have used is http://www.quietcar.net/?google it is superior ( in my opinion ) to the other products and very easy to apply.
To C5 Convertible noise
