SKUNKED....need help !
Old May 2, 2005 | 12:49 PM
BNLspeedaddict's Avatar
BNLspeedaddict
Default SKUNKED....need help !
Last night I was driving home from a sweet drive on PCH. I was near Pepperdine College on a back road when I started smelling a skunk. It was night time so I couldn't see that well, and before I knew it there was a dead skunk in the road. I swerved to miss running it over and could hear it hit under my car, and drag for a few then finally it was gone. My car is slammed mind you... The smell was....and still is! horrible, like gagging horrible..... When I got home, I looked under the car and couldn't see any animal bits or blood, just the smell. What the hell can I do to make the smell go away? My garage is a stink bomb right now! Any suggestions would be great, thank you!
Old May 2, 2005 | 01:08 PM
Freestyler's Avatar
Freestyler
degrease the engine bay
high pressure wash the bottom of the car
then
top off, and 130MPH for 120 minutes ought to do the trick - with the AC and then the Heat on ....
this isnt proven, but it is a suggestion
Old May 2, 2005 | 01:14 PM
corvettekev's Avatar
corvettekev
From experience, skunk spray just has to wear off. You can't hardly make a dent in the smell by spraying the car off. Give it a week and the smell should start to go away.
Old May 2, 2005 | 01:16 PM
sailohio's Avatar
sailohio
Man, that stinks.
Old May 2, 2005 | 01:23 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Get a small bottle (1/2 pint) of "Skunk Away", at least I believe that if the name.
I thin Vets have it in their offices or you can call one and ask.
White plastic squeeze bottle w/blue lettering.
One bottle in a 5 gallon sprayer w/a gallon and a half of warm water usually takes care of it.
Check to make sure there are no body parts of the little stinker wedged in your exhaust system first.
Good luck.
Old May 2, 2005 | 01:36 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Dayum!! It's so bad I can even smell it in this thread Sorry I don't have any recommendation for you on how to get rid of it.
Old May 2, 2005 | 01:43 PM
why_ask_why's Avatar
why_ask_why
wash the car in tomato juice of course
Old May 2, 2005 | 03:41 PM
Trainman-2's Avatar
Trainman-2
Go to a drive through yourself brush less car wash that has an under body spray option. Once you drive it and it starts, you can carefully go back and forth as often as you want to as long as you don't drive out of the beam that keeps it on.
Tomato juice works pretty good if you have a garden sprayer to spray it under the car with.
Get some foam ear plugs and put them in your nose.
Old May 2, 2005 | 03:59 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
A mixture of Dawn dish soup, baking soda and hydrogen pyroxide is what we have used on our pets. I'd try the first two ingredients in a spray bottle. Thanks for the laugh.
Old May 2, 2005 | 05:40 PM
I wouldn't have thought about going to a Vet and getting something that would work on pets. Good idea.
Old May 2, 2005 | 07:36 PM
wit2pz's Avatar
wit2pz
Get yourself some faster headlights and slow the hell down on those back roads! If you couldn't see it in time to slow down and go around or stop, that can be a dangerous practice. I've seen dead deer, bear, dogs, and even buzzards in the road, and none of them do any good for a Vette!
Old May 2, 2005 | 07:45 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
My 100 watt euros are good for 150 MPH on a moonless night.-If you were so inclined.
I haven't tried that myself.
Last edited by madeouttaglass; May 2, 2005 at 07:46 PM. Reason: better tell the truth before I get flamed
Old May 2, 2005 | 07:50 PM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Originally Posted by sailohio
Man, that stinks.
Old May 2, 2005 | 07:51 PM
Monster231's Avatar
Monster231
mix vinigar and Lemon juice in a spray bottle and douse your tires. Thats where the smell is and this combo will nuetrilize the chemical compoound of the "stink"
Old May 2, 2005 | 10:18 PM
PaulaH's Avatar
0PaulaH
Former Vendor
When my dog got sprayed, my vet told me to get this..
Massengill Douche! It works on dogs..so douche your car!
Good luck!!!
Old May 2, 2005 | 10:26 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Tis The Season
Bagged one myself first of April....only mine was alive.
I left car outside for 2 nights......tried spraying underneath at carwash the next day Didn't help. Without a way to get underneath....it's pretty tough. I left it out all day long with the doors open and that helped too. I did NOT give it a douche though
The stench went away in a week or so. I wouldn't be afraid to drive in some serious rain for awhile either. I think that helped mine also.
Good luck...it does eventually go away.
Old May 3, 2005 | 12:12 AM
MY1STPEWTER's Avatar
MY1STPEWTER
Well I've got one you might not of heard of before. A man told me once that he was bird hunting and had no more than let his two bird dogs out when both of them got sprayed. He took them back to the house and tried everything he had ever heard of to no avail. He called his neighbor who had the reputation of being a mountain man of sorts and asked him if he had any idea's as he had tried everyting. The man told him to start brewing coffee and when it had cooled enough to pour on the dogs to start wetting them down with it. He said it worked and no more smell. I don't know if this would apply to the bottom of a car, but if none of the above work I guess it would be worth a try.
Old May 3, 2005 | 07:08 AM
Dark-Knight's Avatar
Dark-Knight
, it works!
To SKUNKED....need help !
