[Z06] 2001 Z06 vs Later Models
Old May 2, 2005 | 04:14 PM
Super Trooper's Avatar
Super Trooper
Navigator
Default 2001 Z06 vs Later Models
what makes the 20hp difference betweent the 2001 Z's and the later models. i looked up what i could about the differences and it seems to me the major difference was the air box...i know the air box doesn't make 20hp difference, so what else is there
Old May 2, 2005 | 04:32 PM
XotiK ZO6's Avatar
XotiK ZO6
I had the same questions and if memory serves there are 3.
- The MAF does not have the screen on 02 and up.
- The cam is slightly bigger.
- The intake manifold was reworked for 02 and up.
I think that was it.
Old May 2, 2005 | 04:33 PM
OutlawDon's Avatar
OutlawDon
Also,no pup cats on 02+ models.
EV2DEMON's Avatar
EV2DEMON
I believe the 02-04 heads flow more as well.
Old May 2, 2005 | 04:41 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
This question comes up all the time. Do a search.
http://www.c5registry.com/2k2z06/index.htm
Old May 2, 2005 | 05:46 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Some of the info above is not correct. Here are the differences:
1. LS6 engine (Z06 model) receives 20 horsepower increase, to 405 hp, and receives 15 foot pounds more torque for a total of 400 lbs. ft. of torque - This was done through a few changes, mostly the Cam though
2. Pre-cat deletion
3. Revised rear shock valving
4. Aluminum front and rear stabilizer bar links
5. Z06 wheels are now cast aluminum, not forged aluminum
6. Head-Up Display (HUD) now standard
7. Cam/Valve/Spring change - Valves were sodium filled to reduce weight
8. Electron Blue exterior color.
9. Speedway white was discontinued
MAF did not change
Intake is the same on all LS6 engines
Heads on LS6 engines are all the same sans the valve's - flow is the same - 243 casting for the LS6 all years
Old May 2, 2005 | 05:55 PM
Super Trooper
Navigator
thanks for your help, i hate that mine is 20hp less but it is still a great car
Old May 2, 2005 | 06:04 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
2. Pre-cat deletion
MAF did not change
I am pretty sure the air box changed a little bit. I was reading some where it was opened up about 6 inches and they had some pictures as well. Here is a link: http://www.c5registry.com/2k2z06/page3.htm
Old May 2, 2005 | 06:15 PM
1 Nasty Z's Avatar
1 Nasty Z
They did change the Air box and the other items as mentioned above. The air box looks like the same thing from on top but underneath the opening was made bigger. If you were going to mod a 01 Z it really wouldn't make a difference if 01 - 04 other than suspension since you would be changing most of the above items if not all. Been there and done that.
Old May 2, 2005 | 10:29 PM
RussBt's Avatar
RussBt
MAF did not change
Yes it did.
Old May 2, 2005 | 10:53 PM
User 81424's Avatar
User 81424
Originally Posted by rbartick
Yes it did.
Are you sure?
Reading is fundamental.
Old May 2, 2005 | 11:40 PM
RussBt's Avatar
RussBt
Originally Posted by CPT Z06
Are you sure?
Yup.
Old May 2, 2005 | 11:47 PM
Internets_Ninja's Avatar
Internets_Ninja
if i descreened my 01 Z, would i need to program the PCM with the 02 MAF table?
Old May 3, 2005 | 05:34 PM
Ruby6spd's Avatar
Ruby6spd
Are you sure?
Good info for me cause it looks like the previous owner of my car switched the MAF to the 2002 design. Thanks
Old May 3, 2005 | 06:06 PM
M_T_0's Avatar
M_T_0
most likely he just poped the screen out of the MAF.
More Than Zero
Old May 3, 2005 | 08:15 PM
Ruby6spd's Avatar
Ruby6spd
What is the exact difference then? Or is it just the deletion of the screen?
Old May 3, 2005 | 09:38 PM
Z06LUST's Avatar
Z06LUST
St. Jude Donor '12
Am I correct in recalling that the fuel system was changed in mid -03 as a result of C6 engine work???
To 2001 Z06 vs Later Models
Old May 3, 2005 | 10:15 PM
User 81424's Avatar
User 81424
Originally Posted by 04retro
Am I correct in recalling that the fuel system was changed in mid -03 as a result of C6 eingine work???
Yes.
Old May 4, 2005 | 09:48 AM
Ruby6spd's Avatar
Ruby6spd
Yes.
More info on that change? First I have heard of it
Old May 4, 2005 | 09:52 AM
XotiK ZO6's Avatar
XotiK ZO6
