Steering recall
Old May 3, 2005 | 09:59 AM
Vikes's Avatar
Vikes
Cruising
Default Steering recall
I got my first vette six months ago. Now, I’m trying to learn all the in’s and out’s of the car. It’s a 99, 6spd, coup and I just receive a recall notice in the mail yesterday. It’s for the column lock recall. I’ve seen a lot of threads on the column lock issue, but I’m not clear about the best solution. Should I take the car in and have the dealer fix it, or do something else. If something else, what would that be? Thanks for your help and this is a great site for needed information. It’s another added value when you own a vette and like to do your own work!
Old May 3, 2005 | 10:04 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
The 1st thing you need to do is to read this thread
Old May 3, 2005 | 10:07 AM
Ghost Vette's Avatar
Ghost Vette
I would have the recall done. Since you have an m6, I think all they do is flash the computer. Mine is an A4 and they removed the lock and replace a harness of some type. The m6 even after the recall in some cases can still give you the lock code. Maybe someone with the m6 will chime in.
Old May 3, 2005 | 12:44 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Save time and money and get the lock bypass. thats what most people do here.
Good luck.
Old May 3, 2005 | 12:58 PM
I had the recall done on mine, but I also spent the extra cash for the column lock bypass. No problems with the column locking up.
To Steering recall
