HELP! Check engine
Old May 3, 2005 | 08:17 PM
carguy0625's Avatar
carguy0625
Default HELP! Check engine
Every time I use the cruise control on my 2000 coupe I get a check engine light and when I get home I pull the PCM code P1416 HC for the Air System 2. What could this mean??
Old May 3, 2005 | 08:26 PM
Anthony01's Avatar
Anthony01
Here is the flow chart for that DTC
Document ID# 554726
2000 Chevrolet/Geo Corvette
DTC P1416 Secondary Air Injection (AIR) System Bank 2
Circuit Description
An AIR pump is used on this vehicle in order to lower the tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0125, P0171-P0175, P0200, P0300, P0335, P0336, P0351-P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, P1441 and HO2S DTCs are not set.
The engine is running for greater than 2.0 seconds.
The maximum air flow is 25 g/s.
The Air Fuel ratio is 14.7:1
The engine load is less than 34 percent.
The ignition voltage is greater than 11.7 volts.
Engine is not operating in Power Enrichment, Decel Fuel Shut-off, or Catalyst Over-Temperature Modes.
The engine speed is greater than 750 RPM.
The ECT is greater than 80°C (176°F) but less than 110°C (230°F).
The IAT is greater than -2°C (28.4°F).
The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6.
Conditions for Setting the DTC
The HO2S voltage does not go below 222 mV for 1.3 seconds.
OR
The short term fuel trim does not change more than a predetermined value.
Action Taken When the DTC Sets
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
Carbon build up in the exhaust manifold may restrict the amount of air flow necessary to affect the HO2S voltage. If this is suspected, remove the air pipe from the manifold and inspect the passage.
For an intermittent condition, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
A check valve that flows in both directions causes heat damage to the AIR system components.
Step
Action
Values
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
YES:Go to Step 2
NO:Go to Powertrain On Board Diagnostic (OBD) System Check
2
Install the scan tool.
Start the engine and idle in Closed Loop.
Turn OFF all accessories.
Monitor the Bank 2 Sensor 1 (Right Front) HO2S voltage display on the Engine 1 Data List using a scan tool.
Enable the AIR System using a scan tool.
Observe and record the Bank 2 Sensor 1 (Right Front) HO2S voltage, as the AIR System is enabled.
Does the HO2S voltage drop below the specified value?
222 mV
YES:Go to Diagnostic Aids
NO:Go to Step 3
3
Visually/physically inspect all hoses and pipes for:
Being connected
Clamps are secure on pipes and hoses
No kinks, holes, or pinched hoses/pipes
Components with evidence of heat damage
Did all the above verify to be OK?
YES:Go to Step 4
NO:Go to Step 6
4
Disconnect the hose from the check valve for the Bank 2 AIR System.
Enable the AIR pump using a scan tool.
Is air present at the hose outlet?
YES: Go to Step 7
NO: Go to Step 5
5
Repair the restriction or the blockage in the AIR hoses/pipes between the right exhaust manifold and the point where the system branches to both sides of the engine.
Is the action complete?
YES:Go to Step 8
6
Repair the condition found.
YES:Go to Step 8
7
Replace the check valve. Refer to AIR Check Valve/Pipe Replacement - Bank 2 .
YES: Go to Step 8
8
Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
Start the engine and idle at the normal operating temperature.
Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
Operate the vehicle within the Conditions for Running this DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test ran and passed?
YES:Go to Step 9
NO:Go to Step 2
9
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
YES:Go to the applicable DTC table
NO:System OK
I know you need a scan tool to check some stuff, but it gives your an idea of what the problem might be
Document ID# 554726
