Question about Windshields
Old May 4, 2005 | 12:59 PM
93aqua's Avatar
93aqua
Default Question about Windshields
Mine is scratched up pretty bad.
1. Is there anyway to get rid of all the scratches? They look like, ice scraper scratches; they go in all different directions.
2. Is it a different windshield if you have a HUD?
3. What does it cost to replace one?
Thanks!
Old May 4, 2005 | 01:07 PM
93aqua's Avatar
93aqua
It is different if you have a HUD.
Old May 4, 2005 | 01:13 PM
The HUD windshield is different and more expensive than the regular one. Not sure on the price, but $1500 or more sounds like a number I have heard before. You can talk to a glass shop on whether or not fine scratches can be polished out.
Old May 4, 2005 | 02:21 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Make sure you have glass replacement on your insurance policy.
Old May 4, 2005 | 08:06 PM
DirteeDave's Avatar
DirteeDave
My HUD windshield ran about $1300 installed including the rubber molding.
Old May 4, 2005 | 08:47 PM
mike348's Avatar
mike348
Look on www.autobahnpower.com They have Hud glass for $385.
You have to find an independent to install it.
Old May 4, 2005 | 08:52 PM
Shylor's Avatar
Shylor
Just another reason not to drive the car in the rain or snow. Wipers that have dirt or small stones in the mix can scratch your windshield when it wipes. The same with snow or using a snow scraper.
Old May 4, 2005 | 08:53 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've seen a HUD installed on a "normal" C5 windshield and it worked just fine.
Old May 4, 2005 | 09:01 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Old May 4, 2005 | 09:57 PM
LoneStarFRC's Avatar
LoneStarFRC
I've done a retro install with a HUD. My original windshield works fine.
Old May 4, 2005 | 10:53 PM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
Thanks!
It they are light scratches they may be able to polish out...check with your local Harmon auto glass (or perhaps other do it as well). I am suppose to get mine done one of these days...wiper marks. A lot of folks add HUD to their non-hud cars...I haven't read if they are changing the windshield, or if the difference matters.
Old May 4, 2005 | 11:09 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
If you get a new windshield, you may also consider a Z06 windshield, which is slightly ligher. I think 4 lbs or something like that, but not absolutely positive on the number.
Old May 5, 2005 | 08:18 AM
maxfli's5's Avatar
maxfli's5
i had 4x4 truck that had lots of scratches on the windshield from the mud. really couldn't see that well at night. so thought what the hell i'll try it . its called scratch out i put it on heavy and took a buffer and got to work. but like i say it was on my truck. if your thinking about replacing it what will it hurt to try?
Old May 5, 2005 | 10:15 AM
Tom/99's Avatar
Tom/99
That's the reason I never use the windshield washers. I still have the origional washer fluid in my 85 Oldsmobile.
Old May 5, 2005 | 10:25 AM
93aqua's Avatar
93aqua
Did it work?
Old May 5, 2005 | 01:49 PM
smooth1's Avatar
smooth1
DON'T CHANGE THEW WINDSHIELD!
A few years ago, I scratched up my Z28's windshield pretty bad (don't ask). Just before having it changed, I decided to try some basic auto paint scratch remover. Started with a small scratch in the corner, which completely disappeared! Then did the entire windshield, with amazing results. Make a long story short, it took about 15 minutes, the windshield looked like new, and no distortion whatsoever when looking out.
Disclaimer: the scratches were just light surface scratches, not deep grooves. Good luck!
To Question about Windshields
