Throwing codes..
Old May 4, 2005 | 03:10 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
Default Throwing codes..
Calling the owner of the car I am purchasing real quick and showing him how to check for codes.. will any codes be there that are suppose to be there - like "ok" codes or should there be nothing...
And its turn the key over once.. and hit fuel 4 times and then they will pop up correct?
Old May 4, 2005 | 03:29 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
any help want to make sure the car has no codes b4 i take anymore action in the sale!
Old May 4, 2005 | 03:31 PM
AFVETTE's Avatar
AFVETTE
Turn Key to ON but don't start the motor, press OPTIONS and hold while you press FUEL 4 times.
Tom
Old May 4, 2005 | 03:50 PM
GrayC5's Avatar
GrayC5
Not sure what you mean by "ok" codes, but only Diagnostic Trouble Codes (DTCs), current and history if any, will appear. DTCs can be manually deleted (reset) and history codes will reset themselves after 50 engine starts, so running the codes may or may not tell you anything. Thus, you may want to consider getting a CarFax and/or having a history run on the car before buying.
The following link shows the DTCs specific to each of the C5 model years and provides the correct instructions for accessing the codes:
Computer Codes for 1981-2003 Corvettes
Hope this helps and good luck with the purchase.
Old May 4, 2005 | 03:54 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
thanks for the reply.. carfax and history came back clean just taking EXTRA caution to make sureeverything is perfect. Thanks for the linky
Old May 4, 2005 | 03:59 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
As said before, there should be no codes....i believe hitting the fuel 4 times resets your oil life...but i could be mistaken.
Good luck on your purchase!
Chris
Old May 4, 2005 | 04:09 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
You need to hold the options button down while hitting the fuel key 4 times.. if there are no codes present in a particluar module..the DIC will say for example "BCM- No Codes". I just checked mine this morning.
After the computer has gone through all the modules, it will go into "Manual Mode" and you can scroll back and fourth I belive by using the trip button, etc..
Good luck
Old May 4, 2005 | 04:10 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Tom
To Throwing codes..
