Painting calipers - removing wheels
I didnt do any masking as mine was with a paintbrush.
http://www.z06vette.com/diy_lift.php
How to paint the calipers:
http://www.2phast.com/Corvette/calipers.htm
Use jack stands and a jack. Jack up the front end, take the front wheels off, paint the calipers. Put the front wheels back on, lower the front end, jack the rear, take off the rear wheels, paint the rear calipers, and put the rear wheels back on. Or you could use four jack stands and jack the whole car up and take all of the wheels off. Either way it is your choice.
I did them one at a time, no need to worry about the sensors, they are actually in the rims themselves.
It is actually easier then you think.
Just make sure you jack it from the center of the car and not the side rails and use jack stands for sure, you can't afford for the jack to fail while you're under there!!
Good luck.
I made sure I chocked one of the front wheels before attempting to lift. When I lifted, I put jack stands under the right locations under the car.
Special note for dummies: Loosen the lug nuts BEFORE lifting the car!
Car up, remove wheels, clean calipers(I did mine with warm water and a wire brush), apply primer to calipers(I bought spray primer, sprayed into a container, then brushed on with sponge brushes) apply 1st coat(by the time I got around to the fourth caliper, the first was ready for the second)
Take your time and do it right. Mine took all day on a clear, nice Sunday, from 11am to 8:30 pm. Tired and beat up, but proud of the outcome! Good luck!
quick question for all you guys/gals...why would you not take the the calipers off and then paint them...isn't it a lot of work wrapping everything up?? woudln't it just be easier to just take them off and paint them...with that being said...is there any way you can damage your calipers with the paint...getting paint where there isn't supposed to be paint :o
I thought it was easier to paint them with the calipers off. it's not hard to take the cars off, just make sure you know how to bleed your brakes when you're done.
I did this routine just last week.
if you brush it on...can you see the strokes of the brush in the caliper after your finished painting??? or is the finished product just as good as the spray???
