Gear size
Old May 5, 2005 | 03:14 PM
furio666's Avatar
furio666
Default Gear size
I have a 2003 C5 vert mn6 I got it used and I'd like to know what size gears I have how can I find this out. Thanks
Old May 5, 2005 | 03:26 PM
JoshVette's Avatar
JoshVette
All 6-speed manuals came with 3.42's.
It's only the auto's that came with 2.73 or optional 3.15's.
You have 3.42, but it will tell you on the gears themselves if you want to get up under there and check them out.
Old May 5, 2005 | 03:57 PM
Mike Mercury's Avatar
Mike Mercury
here are some other ways to verify your rear axle ratio:
http://mikemercury.home.att.net/ratio.htm
Old May 5, 2005 | 04:07 PM
BAD Z06's Avatar
BAD Z06
Old May 5, 2005 | 05:40 PM
Unless the previous owner changed the rear end, you will have the 3.42's back there.
To Gear size
