Side Mirror on a C5
Old May 5, 2005 | 03:37 PM
MadRick's Avatar
MadRick
Default Side Mirror on a C5
The passenger side mirror on my C5 popped out...it is now loose and undriveable.
Has this happened to anyone....Can it be fixed or do I need to replace the entire mirror.
Thanks in advance for your response.
Old May 5, 2005 | 03:45 PM
Patches's Avatar
Patches
Jochen did a great how-to repair post that he submitted as a Tech Tip but hasn't appeared yet. Here's the thread. Not sure if your entire housing or just the mirror popped off - this is just for the mirror itself.
http://forums.corvetteforum.com/show...428&forum_id=1
Old May 5, 2005 | 03:57 PM
MadRick's Avatar
MadRick
The entire housing popped out.
Old May 5, 2005 | 04:06 PM
HummelS's Avatar
HummelS
Here is some information I saved from a while back about a guy who does the repair for $60:
just read this in my new Issue#150 NCRS DRIVELINE March-April. This Guy will repair "your" mirror with the "broken clip" syndrome. "A permanent repair, guaranteed NOT to break" Send the complete mirror w/wiring harness, with ck or money order for $60.00 inc. shipping and handling. He offers a two day turn around after the mirror is received. He even offers by phone, mirror removal & installation instructions, ph# 330-783-0083 ext.15, after 4:30 pm 330-757-9466. Name & address: Ed H. Swaneck, 4030 Simon Road, Bordman, Ohio 44512.
Old May 5, 2005 | 04:09 PM
MO94LT1's Avatar
MO94LT1
If you don't mind it not folding in anymore, I have talked to some owners who just used some industrial strength epoxy(glue) and just glued it in place. They say it is solid as a rock...probably only cost a few dollars?
Old May 5, 2005 | 04:11 PM
Patches's Avatar
Patches
Heard good things about this fix too.
Old May 5, 2005 | 04:35 PM
Darion's Avatar
Darion
Yep works good.
Old May 5, 2005 | 04:39 PM
sandmanusd's Avatar
sandmanusd
Dunno about the "cheap fix"..
Mine did that, had to get a whole new one from GM, painted and installed for $280
Old May 5, 2005 | 06:23 PM
Vector's Avatar
Vector
OUCH!!
Ed's the guy you want to send it to. He's done both of mine - at different times. Pull the whole tihing off and drive the car without them - be back in a week or so depending on shipping.
Old May 9, 2005 | 08:48 AM
MadRick's Avatar
MadRick
Default Thanks
Thanks for all the info.....I'm probably going to go with Ed....I need to call him and get instructions on removing it....Unless one of you guys can help me with that.
Thanks again..........
Old May 27, 2005 | 10:48 AM
MadRick's Avatar
MadRick
Default Thanks
Ok....Removed the mirror with help from you guys.....Sent it to Ed....Great service from Ed....he returned it....and I will re-install it tonite.
Thanks to everyone....You guys are great!!!!
Old May 27, 2005 | 11:22 AM
HummelS's Avatar
HummelS
To Side Mirror on a C5
