key fob problem ?
Old May 6, 2005 | 05:02 PM
26sonic's Avatar
26sonic
Default key fob problem ?
I disconnected my battery for the winter (pos terminal) reconnected today and car started right up ! but the remote key fob does not communicate to open the doors or trunk ? put new battery's in both key fobs and still not working ? do i need to get them reprogrammed ? how can i prevent this every year after winter storage ?
Old May 6, 2005 | 05:09 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I think each time you disconnect the battery and leave the car sit a long time the FOB's loose synch with the car. You are going to need to reprogramm them using the DIC...there was a thread on this a few days ago..the instructions are in your owners manul..you need to find FOB training under the options menu.
I can't get the search function to work now or I'd find that thread for ya.
Old May 6, 2005 | 07:17 PM
cenzo's Avatar
cenzo
Try re-synching.
Stand by the driver's door and hold lock and unlock til the horn beeps...10-15 seconds. Should be ok.
Old May 6, 2005 | 08:00 PM
csexton's Avatar
csexton
Originally Posted by cenzo
Try re-synching.
Old May 6, 2005 | 09:45 PM
26sonic's Avatar
26sonic
tried both fobs with the lock+ unlock method, one worked the other did'nt. I'll look at the owners manual to see if there is another procedure to try.
Old May 6, 2005 | 09:52 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
The owners manual will explain how you "Train" the fobs through the DIC. Just did this myself. Simple to do....
To key fob problem ?
