Dash is peeling
Old May 7, 2005 | 02:02 AM
furio666's Avatar
furio666
Default Dash is peeling
Has this happen to anyone it's like a thin plastic coating is comming off.
Old May 7, 2005 | 06:13 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I've never heard of that before. Are you the original owner? If not, maybe someone has used some type of cleaning product on it that's built up. Sounds kind of weird.
Old May 7, 2005 | 06:17 AM
C5naples's Avatar
C5naples
My dash is not peeling. However the side of the console is, on the side to the left of the ashtray where your knee rests when your foot is on the gas.
Old May 7, 2005 | 06:23 AM
OkeeGuy's Avatar
OkeeGuy
this is happening to mine as well...
Old May 7, 2005 | 06:26 AM
DevilDog II
Oldtimer
Is your car older or new?
Old May 7, 2005 | 06:35 AM
You've got a 2003 - hopefully some warranty is still left. Have the dealer replace the peeling parts with new ones.
Old May 7, 2005 | 09:33 AM
jjk2509's Avatar
jjk2509
There is a rubber type coating over the plastic piece that goes around the stereo, AC unit etc. You will need to get a can of spray solvent ( engine grease remover) and spray it on the platic or a rag and you will be able to remove all the loose coating. Be careful not to get the solvent on any other parts.Once you start, it will take a little time but you can get it all off. It will clean up nicely and look like new. It may be easier to remove the entire plastic piece.
Good Luck!!
To Dash is peeling
