Battery Tender Connection?
Old May 7, 2005 | 09:26 PM
MagRedSkull's Avatar
MagRedSkull
Default Battery Tender Connection?
Is it safe to connect the Battery Tender to battery for charging while the battery is still connected to the car?
Old May 7, 2005 | 09:57 PM
csexton's Avatar
csexton
Yes, put the red clip on the positive terminal and the black on the neg. and fire that puppy up!!
Old May 7, 2005 | 10:13 PM
MagRedSkull
Thanks csexton.
Old May 7, 2005 | 10:25 PM
rickko's Avatar
rickko
No problem.
To eliminate possiblity of spark, best to attach leads before plugging in Tender.
..rickko..
Old May 7, 2005 | 10:28 PM
bekdad's Avatar
bekdad
Do you have the instructions with the unit? Mine said to (1) put the red clamp to the + terminal, (2) the black clamp to a ground, (3) then plug it in. Perfectly safe. Mine stays hooked up that way Monday through Friday - never a problem.
Old May 7, 2005 | 10:35 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Black to black and red to red then just plug her in had my car on my battery tender for 5 months and she works just great the best thing i have ever bought for the car to keep her going.
Old May 7, 2005 | 10:43 PM
Dr. Dan's Avatar
Dr. Dan
Fasten the other electrical connectors to the battery bolts, this way you just plug the BT into the plug every winter. Clamps might fall off during a long winter. During the driving season, just push the plug beside the Fuse/relay center.
Old May 8, 2005 | 01:01 AM
1Patriot's Avatar
1Patriot
I use a modified lighter plug for my car tender. Quick and easy to connect and disconnect.
Old May 8, 2005 | 09:27 AM
BobbyO's Avatar
BobbyO
No any problem!
Old May 8, 2005 | 10:16 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Old May 8, 2005 | 10:32 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Yes, but I want to be sure that you don't expect it to charge the battery it is for maintaining a charge more than charging. If your battery is low then use a charger...
Old May 9, 2005 | 12:18 AM
MagRedSkull
I disagree. The instructions are titled "Battery Tender Plus Battery Chargers". The instructions specifically discuss operating in 3 primary charges modes of bulk mode (full charge power 0% to 75% charged), the absorption mode (75% to 100% charged), or the storage/float maintenance mode (100% to 103%).
Old May 9, 2005 | 09:16 AM
charlene's Avatar
charlene
Old May 9, 2005 | 09:28 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Yes, if you have the Battery Tender Plus - if you have a generic Float Charger type of battery tender though...
Old May 9, 2005 | 12:13 PM
SavPrato's Avatar
SavPrato
Old May 9, 2005 | 02:15 PM
wpdjoey's Avatar
wpdjoey
Originally Posted by rickko
No problem.
..rickko..
Old May 9, 2005 | 04:52 PM
Square's Avatar
Square
I have a "Battery Tender Plus" for my 99' coupe. I tried to install the ring terminals, but they were too small to slip over the battery lug bolts. I call the manufacturer, and they said it was ok to cut off the factory rings and install larger ones so that I could use the ring terminal connection as opposed to the clamp connectors. This has worked well for me. The car stays on the tender for weeks at a time and I have not seen any problems.
To Battery Tender Connection?
