battery mat help
There are four bolts holding down the battery tray and they are easy to get to. Look in the center of the tray and there's a hole there with four sides, one bolt on each side. Take them off and you can remove the tray. Then get yourself one of those little magnets on the end of an expanding rod (Home Depot for about $5) and poke around until it grabs the socket. It's down there and you can pull it out (don't ask me how I know).
BTW, while you're at Home Depot, see about getting yourself a longer bolt for the hold down.
Bought the mat....took the battery out, mat in, bolt too short....dropped the socket..
....pulled the battery out....pulled the tray out and eventually retrieved the socket....wasted hour!!
Not smart enough to buy a longer bolt....guess I still have the mat somewhere....another chance to drop the socket!! Just what I need....alittle help from my friends!!
Then, I had just bought some "mods", and had the screen kit, and as noted, (and as I expected) as soon as I took off the fender linder, there the 13mm socket was, so, recoverd that, put the cove's in, etc., and am good to go, got the front's, brakes, cove's, etc.
THANKS
