headlights dimming..??
Old May 9, 2005 | 01:24 AM
themosjohn's Avatar
themosjohn
Default headlights dimming..??
i recently got a 99 frc, and i've noticed that the headlights dim while breaking, and periodicaly while driving. the volt meter shows 14. something and drops a number while breaking. i just wondered if this is a problem anyone else has noticed. one thing which may affect it is that i believe the fan has been set to run about non stop.. i cant say what temp it comes on at, but the car runs pretty consistently around 194 deg.
Old May 9, 2005 | 01:56 AM
red97vette's Avatar
red97vette
the headlight issue is very common, i have it too... its very annoying. Im not sure on a fix... maybe someone will chime in
red
Old May 9, 2005 | 03:15 AM
gairno's Avatar
gairno
Mine does the same thing. When I first had the problem I had the battery checked and it was going bad. Added a new one and the problem went away for a few days then came back. Don't worry about it.
Old May 9, 2005 | 03:32 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Ground Points are corroded. Clean them all - there are 2 for the headlights.
The first is a little black box on the drivers side of the engine compartment next to the alternator and bolted to the frame. The other is on the passenger side between the battery and the engine under the plastic divider.
Also make sure that your alternator ground is clean - it grounds through the top pivot bolt.
EG
Old May 9, 2005 | 09:17 AM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
my car does the samething, and yes, that's really annoying... I will have to go home and try what EnglandGreen said. Thanks for the tips!!
Andy
Old May 9, 2005 | 10:53 AM
themosjohn's Avatar
themosjohn
thanks guys, cant wait to check em. guess i need to put some pictures of the ride up soon as well
Old May 9, 2005 | 12:56 PM
Thanks for the tip.
Old May 9, 2005 | 01:18 PM
Gofasterdad's Avatar
Gofasterdad
I’m not surprised that EG would be right of top of this subject. He’s probably got a separate power plant for the neon.
Old May 9, 2005 | 10:18 PM
themosjohn's Avatar
themosjohn
funny, but i hope he's right
Old May 9, 2005 | 10:49 PM
FallenWhun's Avatar
FallenWhun
my lights dim when the air pump runs...THEN BAMMM get the P0410 code right after...then I clear it and go on with the rest of my day.
Old May 10, 2005 | 02:51 AM
leaftye's Avatar
leaftye
In that case, disable the air pump. I disabled mine....maybe that's why I never notice dimming...
Old May 10, 2005 | 03:12 AM
Stickman81's Avatar
Stickman81
EG
Great information. I'l have to check those tomorrow as my headlights do the same thing.
Old May 10, 2005 | 01:11 PM
FallenWhun's Avatar
FallenWhun
how do you disable the air-pump? in doing so will I get a big back hand at emissions testing?
Old May 10, 2005 | 02:16 PM
leaftye's Avatar
leaftye
Use tuning software. Tell the computer not to report codes, and it'll still pass startup tests that'll allow it to pass the OBDII smog test.
Old May 10, 2005 | 03:02 PM
LANZ06's Avatar
LANZ06
99 FRC and I have the same problem.
Old May 10, 2005 | 04:23 PM
Dragon-Vette's Avatar
Dragon-Vette
Had same problem with my 98....on my car it turned out to be where the wires from the batt. and alt. hook up to the starter....the connections were alittle lose and the conectors were corroded...took them off the starter....cleaned with a wire brush and hooked back up tight.....no problems with the lights dimming since.
Hope this helps.
JAck
To headlights dimming..??
