Traction Control with Automatic Trans Question
Old May 11, 2005 | 09:01 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by REDRWUT
it sounds like the traction control was still engaged. you need to hold the button down until it says " competetive mode" in the gauge area.
Some cars do not have "active handeling"
Just shut the TC off, is the car an A4 or M6?
Old May 11, 2005 | 09:05 AM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
Mines an A4.
Old May 11, 2005 | 09:45 AM
screw991le's Avatar
screw991le
Originally Posted by DJN
Mines an A4.
Year and do you have active handeling?
Old May 11, 2005 | 09:49 AM
ORANGEBROTHERS
02 only with TC no AH.
Old May 11, 2005 | 11:27 AM
G-lock's Avatar
G-lock
That's odd, all 2001 and later C5's have AH as standard equipment. Jeff
Old May 11, 2005 | 11:34 AM
G-lock's Avatar
G-lock
Originally Posted by FASTENUF
For what ever reason, every once and a while when I turn off my AH/TC it doesn't disengage(even though it says its off) but when you try to do a burnout the car just kind of studders. Usually if I just turn it back on, then back off, it works
My 99 with AH does this as well, I'm pretty sure it's the A4 trans abuse mode not TC that stutters the engine and reduces output. I need to disbale the abuse mode and see if it changes the behavior. Jeff
Old May 11, 2005 | 02:31 PM
Gimmesum HP's Avatar
Gimmesum HP
After having LS1 edit done and a full exhaust installed on my 99 A4 I can now turn off my traction control and bounce off the rev limiter through 1st and 2nd and continue in 3rd boiling the rear hides if I have enough space since the back end is really trying to come out by then. I do not have competion mode but my owners manual does tell me how to engage it if I were to have that option. I believe it is called torque management on the A4 so you don't blow up the tranny.
Old May 11, 2005 | 02:36 PM
ORANGEBROTHERS
Then maybe I have it just not sure. Only had the car for a few months and am still trying to figure everything out. I know I have the switch on my center console that has TC so how do I know if I have AH?
Old May 11, 2005 | 06:31 PM
pewterwest99's Avatar
pewterwest99
Again, IF IT SAYS" ACTIVE HANDELING" ON YOUR CENTER CONSOLE BUTTON, Then you have active handeling. If it does not say "active handeling" then you do not have it and your car is ONLY equipped with Traction control.
Old May 11, 2005 | 07:47 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
i think he wants you guys to listen to what he is saying!!!
com'n boys..its that easy!!!! either u have it or not!!! LOL
Aj
Old May 11, 2005 | 07:54 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Originally Posted by 98NassauBluC5
My '98 has the T/C button, and after reading this I tried what you said with no results. I'm not sure if '98's just didn't have Comp. Mode or not?
It's not the traction control, it's the active handling control. It started being standard about halfway through the 1998 model run. My 98 doesn't have it either.
Old May 11, 2005 | 08:43 PM
shurite44's Avatar
shurite44
I just put the car in third. It still takes off in first. Then I powerbrake until the wheels break loose then I give it about half throttle to do a burn out. Someone chime in though I am confused. If you put the car in second doesn't it still start in first. It just won't shift to third.
Old May 11, 2005 | 08:49 PM
  #33
nmbis2k's Avatar
nmbis2k
Originally Posted by ccgtvette
I have a 2000 A4 and found out that not all vettes have Competitive Mode. Mine did not. Correct me if I'm wrong, some 2000 have it and all after have it.
Every car I have seen, has it. Plus, listed as a std. feature in the owner's manual.
Old May 12, 2005 | 12:20 AM
  #34
LS1_redvette's Avatar
LS1_redvette
Mine has it (02). And yes 3rd with an A4 in CD will def smoke em' . All I have to is get someone to film my stupidity
B
Old May 12, 2005 | 07:41 AM
  #35
Special K's Avatar
Special K
Originally Posted by 2003vert
Are you saying there is more torque in 2ND off the line???
No. I'm saying if you start in 2ND you will not overpower the car and will have better burnouts. You also won't bump the rev limiter.
Old May 12, 2005 | 07:42 AM
  #36
Special K's Avatar
Special K
If you put the A4 in 2ND it will start in 2ND, not first.
Old May 12, 2005 | 08:44 AM
  #37
ORANGEBROTHERS
Ok I just checked and it does say Active handeling on the console right under the button, my mistake I thought that was TC.
Anyway, so given the fact that I have an 02, A4 with TC & AH back to my original question. How do I smok'em?
Old May 12, 2005 | 08:50 AM
  #38
mikestuff's Avatar
mikestuff
Is this true for cars without active handling? Mine is either traction control on or off regardless of how long I hold the button. Mine is a 99 A4.
Old May 12, 2005 | 08:55 AM
  #39
Sneaky Fast's Avatar
Sneaky Fast
My 98 does not have Competitive Mode either its just on or off, I am not sure if that was part of the system in 98. It either came towards the end of 98 or after that? Someone on here will know.
