General question
Old May 9, 2005 | 11:02 PM
Cali17's Avatar
Cali17
From: West Hollywood California ! Now Miami, Florida
Default General question
Hey all just got a C5 FRC ... but i dont have my manual yet. Anyway the dash says serv tire mon sys ??? what does this mean .. the car runs great and everything . but i would really like to know what this means and would like to fix it if anything as soon as possible ...
Well let me know what you all think . and I am looking forward to seeing all the Cali people on 5.15.05
Old May 9, 2005 | 11:04 PM
c52k1NY's Avatar
c52k1NY
I think you may have a tire pressure sensor that isnt working right, not sure though.
Old May 9, 2005 | 11:07 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
You're having the same problem I'm having. It's a tire sensor going out. My DIC will also say "RIGHT FRT. TIRE FLAT". Here's a thread I started in C5 Tech:
http://forums.corvetteforum.com/show...222&forum_id=1
Old May 9, 2005 | 11:08 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What year?
The Sensors are not interchangeable. 97-99 , 00 , 01-04
Of course the 2000 being the most expensive but almost double.
Old May 9, 2005 | 11:18 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Either the battery in the sensor is dead or the sensor needs to be re-programmed. To program the TPM sensors follow these steps:
The tool Required is ( J 41760) Tire Pressure Monitor (TPM) System Programmer or a good size magnet will work. I used a speaker magnet when I reprogrammed all 4 on a previous C5 after installing new wheels, tires and sensors.
You must make sure the car has been stationary for at least 2 minutes before attempting to program the TPM sensors.
Turn the ignition to ON.
Press the RESET button in order to clear any IPC display warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the DIC RESET button for 3 seconds.
Press the OPTIONS button again until the TIRE TRAINING message appears.
Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
Install the J 41760 tool or magnet over the left front valve stem.
The horn will sound, indicating the left front TPM sensor is programmed.
If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool or magnet. This procedure may have to be attempted up to three times in some instances.
When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
LEARN R FRONT TIRE
LEARN R REAR TIRE
LEARN L REAR TIRE
The programming mode will be cancelled if any of the following occur:
The program mode is exited through the DIC.
The ignition is turned to OFF.
All four sensors have been programmed.
The TPM system has been in the program mode for longer than 2 minutes and no sensors have been learned.
If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
You need two people to program the sensors. I had my wife help.
Old May 9, 2005 | 11:20 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
PM me with your email address and year of vette and I will see if I have the manual in pdf for you
Old May 10, 2005 | 12:54 PM
Cali17's Avatar
Cali17
Default Ok .. thanks for all your help guys
Thanks all i shall try and attempt to do all that you have written .. and for a more detailed explaination just write to me at cali17@gmail.com and i have a 1999 Hardtop 6 speed manual . etc .. in fact i have posted and explained in the past recently .. so simply go to the C5 for sale section and look for my post cali17 .. the search is finally over !!
LOL
once again thanks all !
I totally cant wait for the 15th !
PEACE !
To General question
