key fob programming
Old May 11, 2005 | 09:36 PM
Frby98's Avatar
Frby98
Default key fob programming
Everyone:
I have heard that you can program the different key fobs to be "driver 1" and "driver 2" so that it sets up the seats and mirrors to the different settings.
Any ideas how to do this? I just bought a second key fob.
Thanks in advance.
Old May 11, 2005 | 10:03 PM
iteachflyin's Avatar
iteachflyin
If you have the owners manual for your car the procedure is in there for programming fob1 then fob2. I'm pretty sure you can even go to fob3 if you have one. I used the procedure, had someone else read it to me as I did, but it was damn simple as I remember. Just use your manual, it'll be easier than someone explaining it.
Old May 11, 2005 | 10:40 PM
Alcee1's Avatar
Alcee1
Anyone who wants it, copy and paste.....
Corvette keyless remote programming instructions:
To match transmitters to your vehicle:
1. Turn the ignition key to the ON position.
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once. The message HOLD LK+UNLK 1ST
FOB will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned, the DIC will display FOB LEARNED and then prompt you to learn the nest transmitter.
7. Repeat steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programing mode will shut off if:
You don't program any transmitters for two minutes
You take the key out of the ignition.
You have programed three transmitters.
To key fob programming
By Michael S. Palmer | 2026-06-03 11:00:24
