interior lights????
Old May 13, 2005 | 08:22 PM
jman1's Avatar
jman1
Default interior lights????
ok.... i noticed something a little wierd.... when i shut off my car,pull the key from the ignition, get out and close the door all the interior lights go out.....if i open the door and close it again with out putting the key back in the ignition (like if i forgot something in the car) the interior lights will stay on when i close the door...??? unless i lock it am i missing something...anyone know why???
Old May 13, 2005 | 08:52 PM
Shylor's Avatar
Shylor
Normal.....the program is set so when you lock the car it knows you won't be getting back in right away, so the lights go out.
Old May 13, 2005 | 10:47 PM
iteachflyin's Avatar
iteachflyin
I've been chasing an interior exit lighting issue for a long time now and I can't get consensus on this question, perhaps you know ...
At night, when you shut down the ignition and pull out your key, do your interior footwell and rear hatchback lights illuminate?
Old May 14, 2005 | 08:35 AM
jman1's Avatar
jman1
hmmm... i'm not sure...i only noticed the mirror lights coming on... i'll check it out tonight
To interior lights????
