[Z06] Big difference in power when the temp went up.
Old May 15, 2005 | 04:23 PM
Innovator's Avatar
Innovator
Default Big difference in power when the temp went up.
I know hotter air makes less power due to it's lower Oxygen content.
This engine seems to be affected even greater than others I've had in the past. The power difference between 45 and 75 degrees is large.
I have also noticed that when I shift near redline, that I get a quick loudish detonation as I hit the gas right after the shift. Just a single detonation, and the ECU quickly compensates for it. Is this normal for this car?
I recently installed the Vararam intake. At first, I thought I noticed a difference, but now I'm not so sure... Isn't this intake supposed to be the best?
Anyway, I'm going for a ride
Old May 15, 2005 | 04:35 PM
slong's Avatar
slong
I noticed the huge power dip at high temp. during 100+ weather also. Are you bouncing off the rev. limiter between shifts? And for the VR - many feel the added MPH behind the seat, also several disagree. VR has been proven at the track. Good luck and enjoy.
Old May 15, 2005 | 06:32 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
All cars loose some power in hotter temps, but to me this car still feels fast in the hottest weather whereas my '97 Cobra felt like a complete slug when the temps came up. I dont' have any detonation problems, not sure why you would... do you live on the west coast and have to use lower octane gas?
Old May 15, 2005 | 09:24 PM
Pumba's Avatar
Pumba
Richard,
Get yourself a Tune ASAP. With the VaraRam you are able to flow much more air than with the stock air cleaner. Your engine's PCM is not able to increase the fuel flow enough to compensate for the increased airflow. You will probably find your air-fuel ratios in the 14.0 to 14.5:1 range. If that is the case it will cause the detonation. You need to get your air-fuel ratios back in the 13.0 range.
I just went through the same thing in my Z06. I picked up 30 RWHP by correcting the air-fuel ratios.
Old May 16, 2005 | 06:05 PM
Innovator's Avatar
Innovator
Originally Posted by Pumba
Richard,
Thank you for your advise. Although I HIGHLY doubt there is that much more air flow through the Vararam filter than with the stocker.
Old May 16, 2005 | 11:09 PM
slong's Avatar
slong
To each his own. You now have a ram air system with the VR. Trust me you are getting much more air at speed. Now for the tune, I believe Innovator is correct, but the problem is hard to duplicate the VR performance when you’re at a stand still dyno run. Good tuner will compensate for this, so a local shop has told me about mine. Maybe you should go back to OEM air box. Good luck either way.
Old May 17, 2005 | 08:29 AM
Innovator's Avatar
Innovator
Don't get me wrong, I'm sure this filter offers some more airflow. But what I meant was that the increased airflow should still be within the ECUs window of adjustment without the need for a tune.
What has me a little concerned though, is that my car seems a little slower now, if anything...
Old May 17, 2005 | 12:31 PM
BLU-BY-U's Avatar
BLU-BY-U
I keep reading this time and time again....a 13.0 or even a 12.0 a/f ratio guarantees nothing as far as detonation. A 12.0 a/f ratio can detonate if the other key tuning parameters aren't dialed in. You can even have audible detonation and not set the knock sensors off. It happens.
I will agree with the rest of the advice....seek a professional tuner that can handle all of the parameters and make adjustments accordingly.
Old May 17, 2005 | 03:55 PM
Shylor's Avatar
Shylor
Hotter temps = less power
But
Hotter temps = better gas mileage
Old May 17, 2005 | 06:03 PM
Innovator's Avatar
Innovator
But
I wouldn't have bought this car if I were worried about gas mileage
Old May 17, 2005 | 06:47 PM
Shylor's Avatar
Shylor
Well I'm not worried about it either but, it's nice to know there are benefits to warmer weather.
Old May 17, 2005 | 07:13 PM
Innovator's Avatar
Innovator
I dunno.
I installed the Magnaflow X pipe, and now the car sounds wimpy. Now the Vararam is making the car slower?
Old May 18, 2005 | 08:07 AM
Gonzo's Avatar
Gonzo
Richard,
This is correct, your A/F ratio should be around 13 with the Vararam. If you doubt this call Vararam and speak to the owner. I did and he told me the A/f with the vararam is best around 13.
I have a Vararam and I noticed a diffrence at highway speeds
Old May 18, 2005 | 08:15 AM
Innovator's Avatar
Innovator
Ok. So how do you go about changing the AF? I have a FJO wideband gauge I can install easy enough....
To Big difference in power when the temp went up.
