Help FUEL gage ...
Old May 16, 2005 | 01:08 AM
Houstontrader's Avatar
Houstontrader
5th Gear
Default Help FUEL gage ...
Im new to this webiste and I greatly appreciate all the help and suggestions. This is my first corvette and it is a Red Targa 6 speed 2000 vette. Couple mods include corsa exhaust, intake ...
Now I just hit 31K miles on it and my FUEL gage completely went to 0%. I have filled the car up and the neadle droped to 0% after 10 mintues of normal driving. Any suggestions?
I read previous post in regards to adding TECHRON to your gass. I tried that today. I will post if that helps.
Does anyone else have any other suggestions?
thank you again for your time.
Old May 16, 2005 | 02:01 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Welcome to the forum with some of the best people on the planet
Congrats on your ride and may you have miles of smiles
Don't forget to wave
The techron has worked for many ... other times the fuel sending unit is (or becomes) faulty.
Hope your issue gets resolved with the techron.
Old May 16, 2005 | 02:02 AM
gordonb50's Avatar
gordonb50
You've already done what most would suggest ... view past threads. And, it looks like you've made the correct choice. The Techron should clear up the problem. It did for me. And, buy good gas. The key to keeping the guage working properly is using gas with low sulpher content.
Old May 16, 2005 | 02:04 AM
1998 GTR's Avatar
1998 GTR
Mine did the same thing yesterday! Just driving down the road, more than 3/4 tank and the gauge goes to empty and the DIC dispayed "Low Fuel". Turned it off and back on -- Still at empty. Got home and turned it off and back on, then all was normal??? Not done it again since. My ignition switch sometimes sticks where it's not making complete contact and none of my gauges or dash lights work. But I just jiggle it a bit and everything comes on. The fuel gauge thing seems to have been something different -- Gauges didn't go off -- And DIC was reading the gauge as empty. I have no answers, just guesses . . . Bad fuel level sensor? . . . PCM glitch? Anybody else had this problem and figured out what it was?
Mine's a '98 Vert with about 30K miles.
George8211's Avatar
George8211
http://forums.corvetteforum.com/show....php?t=1087942
I put this link in your other post in the tech forum... Welcome to the Corvette Forum
Old May 16, 2005 | 02:18 AM
Houstontrader
5th Gear
thank you guys, as soon as it works I will let you all know
Old May 16, 2005 | 07:18 AM
Besides the Techron, maybe try switching brands of gas. If those things do not work, could be the sending units. Hope the Techron works for you.
Old May 16, 2005 | 07:51 AM
BT-01-vette's Avatar
BT-01-vette
Techron or BG-44K should help. Follow the instructions and just don't burn it out, let it sit in the tank for a few days. Usually one or two tanks does it for me. The best brand gas to use is Chevron, Shell Vpower and Texco.
Old May 16, 2005 | 08:07 AM
Paul Scarpelli's Avatar
Paul Scarpelli
Default Bad design with no fix.
Using nothing but Chevron, I've had this problem almost continuously for five years in my 2000 Coupe. I've had the fuel sensors and sending units replaced three times, and the problem always comes back. I've used Techron, and I always buy fresh gasoline from a busy station. No one has yet to give me a plausible reason for the fuel gauge instantly dropping to empty, but it's no fun on a long trip when you're out in the middle of nowhere where Jesus lost his shoes, and it appears you're on empty.
This Wednesday evening, I'm driving 850 miles to Fichtner Chevrolet to trade the car in on a DSOM Z51 Coupe, and as perfect as the car has been, the gas gauge will be on empty for half the trip. That's just the way it is.
To Help FUEL gage ...
