Belt Tensioner?
Old May 16, 2005 | 04:21 PM
utrico's Avatar
utrico
Default Belt Tensioner?
I have started to get a little squeaking here and there on my 97' with 65,000 miles. I went by a parts store and he told me my tensioner is going. He pushed on it and it could move about a 1/4". Is he right? If so, is it expensive to fix?
Old May 16, 2005 | 04:43 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
had mine replaced by the dealer at around the same mileage.. The whole deal was less than my deductable on the extended warranty.. think it was $85.00. You can do this by yourself..Get the parts from one of the forum dealers.
Old May 16, 2005 | 05:15 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
By "squeak", if you could describe it as a "chirp", then it could be the belt tensioner. It was VERY easy for me to watch someone change mine! (if you see me with a wrench in my hand you better hope I am not working on YOUR vette... ...I'm a jinx).
However, I found out it wasn't the TOP tensioner that was "chirping", it was one of the lower ones. In any case, all tensioners changed out at close to 100k miles
Old May 17, 2005 | 11:59 AM
maxfli's5's Avatar
maxfli's5
60 to 70 bucks the one on the a.c. is a bit** to get to
Old May 17, 2005 | 12:12 PM
diyguy's Avatar
diyguy
Only if you can isolate that sound directly to the tensioner... otherwise just try new belt.
Mine had an on/off again sound like a bird chirp, then the instant I hit it with belt dressing it went away. Got new belt - problem solved.
Old May 17, 2005 | 12:52 PM
Ghost Vette's Avatar
Ghost Vette
Changed mine and a new belt in about 15 minutes. Very easy to do. Remove the belt , take out two bolts, replace new pulley and put on new belt. Stopped the chirping. I decided to replace both since I had to remove the belt anyway for a new one. Not sure which was making all the noise.I had 68 k miles.
To Belt Tensioner?
