floor jack
Old May 17, 2005 | 09:50 AM
corvettejaune's Avatar
corvettejaune
Default floor jack
Hello i have buy a floor jack 1.5 ton capacity at SEARS (craftsman) cant you tell me if is strong enough for lift my 2000 vette
thanks new member
CORVETTE JAUNE
Old May 17, 2005 | 09:55 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Remember you're not lifting the entire car, only a portion of it. The car only weighs about 3300 lbs., so a jack rated to lift 3000 lbs should be plenty.
If you're buying a jack - think about finding one that is a low profile jack and be sure to follow proper jacking techniques - the rocker panels on your car are easily damaged if not lifted properly.
Here's a link to a web page that might help.....
http://www.idavette.net/hib/C5diy/c5diy1.htm
Oh yeah - welcome to the best forum on the planet!
Old May 17, 2005 | 09:59 AM
corvettejaune
thank a lot very kind
regard mike
Old May 17, 2005 | 10:08 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With the above. And welcome to the forum. Your going to like it here.
Old May 17, 2005 | 11:46 AM
rickko's Avatar
rickko
Hi! Welcome, :
I bought a lightweight, 1.5 ton low profile (3" height) jack from Pep Boys a couple of months ago. I've used it regularly to lift my stock height vert. Works good except its a little hard to control the speed of descent when lowering the vehicle. Jack is made by Torin.
Note, 'capacity' on label. Pic is of it lifting heaviest part of car, the front.
..rickko..
Old May 17, 2005 | 11:52 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Welcome to the forum
I have the exact same one (Sears Craftsman). Works fine!
Old May 17, 2005 | 12:03 PM
v.vet's Z06's Avatar
v.vet's Z06
I have that exact jack.....works great....replaced my stock sway bars with Z06 bars a couple of weeks ago!!
Old May 17, 2005 | 07:35 PM
DirteeDave's Avatar
DirteeDave
I have that jack and it works great.
Old May 17, 2005 | 07:39 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Welcome to the Forum
Old May 17, 2005 | 08:13 PM
Shylor's Avatar
Shylor
If this can lift the car your 1.5 ton can.
Old May 17, 2005 | 08:26 PM
VLVETTE's Avatar
VLVETTE
Me too works fine and it's purdy
To floor jack
