dynatech heat issues?
Old May 17, 2005 | 10:57 AM
molson's Avatar
molson
Default dynatech heat issues?
Just purchased mine and was reading over in c6 section about 3 fires caused by dynotechs..(I know they are a different application).
I have read only good things about them here.
I would like to know what precautions/tips I can use to shield components from heat..Any ideas would be great
Old May 17, 2005 | 11:08 AM
scottyo's Avatar
scottyo
Default Dynatech
Installed the Dynatech Supermaxx system including high flow cats and x-pipe on my 04 vert MN6 on May 4th. The installation went very smoothly. Excellent fit with no ground clearance problems. It fits up nice and tight like the stock system. No problems with excess heat, and I spent a morning at the strip. Nothing that I can see is close to coming it contact with the system. Care needs to be taken when routing the O2 sensor cables. My 04 required extensions for the rear O2's. Highly recommend the system. Also installed Indy pace Car cat back at the same time. Performance and sound is awsome!!
Hope this helps.
Old May 17, 2005 | 11:21 AM
molson's Avatar
molson
I am wondering how close the hydraulic clutch line is to the headers?
I saw some scary pics over in c6...
Maybe I should stay away from there..
Old May 17, 2005 | 11:33 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Hope this helps.
Keep ALL cables, wires, pipes away from your headers (no matter what brand) and you'll be fine.
Old May 17, 2005 | 12:25 PM
SDWYZ C5's Avatar
SDWYZ C5
Hope this helps.
I have the same exact setup, And I love them!!!
Old May 17, 2005 | 12:56 PM
WKMCD's Avatar
WKMCD
Hope this helps.
Dynatechs and Pace Car - Priceless...
My neighbor told me when I was pulling out last week (I'm always careful to keep it as quite as possible in the neighborhood) his 3 year old son looked up and said "Daddy, airplane".
Old May 17, 2005 | 04:28 PM
molson's Avatar
molson
I can't wait to get mine installed..
I will be doing it myself so I really need to take my time and watch all my clearances.
I really enjoyed your write up E.G..you have a sweet machine.
I will be waiting for your H/C write up
Old May 17, 2005 | 07:45 PM
As long as they are installed properly, there should be no worries. Everything should have sufficient clearance from the pipes.
Old May 17, 2005 | 10:13 PM
0EG@EnglandGreen
Supporting Tuner
Thanks.
It will Just be Cam/Springs right now. Heads will have to wait until I finish my suspension (Z06 springs/Hotchkis sways/sticky tyres)
EG
To dynatech heat issues?
