Potential Battery Problem. Help needed please...
Old May 17, 2005 | 09:26 PM
C5Hokie's Avatar
C5Hokie
3rd Gear
Default Potential Battery Problem. Help needed please...
Had to jump the vette tonight. Haven't driven much in several months, but ran the radio while washing/waxing for about 1.5 hours & then couldn't get it started. Jumped it, got it started, but everytime I tried to put it in gear & go, it would die. Voltage gauge reads 13.0V. Time for a new battery, or is there some other potential problem?
Old May 17, 2005 | 09:30 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Replace your battery, you don't drive that often so I would go with the YELLOW Top
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
what battery is currently in it? If its stock get rid of it no matter what.. also what year vette is it? Cause the stock battery prior to 2001 = a no no to keep.. i almost found that out the hard way.. it can leak and ruin your computer!
Old May 17, 2005 | 09:32 PM
C5Hokie's Avatar
C5Hokie
3rd Gear
It is an '03 and is the stock battery. Approx. how much will a new one run?
Old May 17, 2005 | 09:36 PM
Sponge Vette
Opitma Yellow or Red top should be about $100 to $120 tops
Old May 17, 2005 | 09:56 PM
C5Hokie's Avatar
C5Hokie
3rd Gear
Thanks for the help
Old May 17, 2005 | 10:32 PM
ttaylor's Avatar
ttaylor
Is it still under warranty, the battery is between the bumpers? When you put the new battery invest in a battery maintainer not a charger and should help eliminate your problem with not driving much.
Old May 19, 2005 | 08:50 PM
KBC5's Avatar
KBC5
8th Gear
I have 2004, called Optima (www.optimabatteries.com) because they don't list a battery for '04's. They recommended a 75/25 Red Top.
To Potential Battery Problem. Help needed please...
