handling issues
Old May 17, 2005 | 09:59 PM
Vogos97C5's Avatar
Vogos97C5
Default handling issues
Ok, I bought my car used, but even when I first got it, it seemed like if you would weave back and forth, the thing felt glued to the road, and smooth. Now, if I do that, it feels really loose in the rear, and just not right, sometimes un safe. Only thing I can think of is that I have the EMT's on the front and regular radials on the back. Although, when I went up to Detroit last year, it was at night and I hit like 58 million pot holes, give or take one or two, and since then it hasn't felt as smooth or comfortable. Suspension just worn you think, the potholes kind of just finished it off?
Old May 17, 2005 | 10:51 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I would not mix EMTs and non-EMTs, the EMTs have a different construction and that may be the cause of your problem. I remember when radials and bias ply tires were mixed they would behave like you described.
Old May 18, 2005 | 12:01 AM
NitrousMan's Avatar
NitrousMan
You must be kidding, potholes in Detroit?? I never see any of those around here.
Old May 18, 2005 | 12:10 AM
pewterwest99's Avatar
pewterwest99
maybe the shocks, I have the same problem on my '99
Old May 18, 2005 | 05:25 AM
yellow01's Avatar
yellow01
HOnestly I think your problems are 100% related to your mixed tires, especially since you note the problem in the rear.
EMTs are VERY stiff compared to standard tires, so relatively the rear will feel vague compared to the front.
Anything could be the issue (e.g. shocks) but my first guess is still the mixed tires.
Old May 18, 2005 | 05:55 AM
I'm thinking it is related to the different tires front and rear, but you may want to check your suspension too. Potholes can be rough on the components.
Old May 18, 2005 | 06:58 AM
Vogos97C5's Avatar
Vogos97C5
Man I was getting so ticked off while driving thru there, I couldn't believe how bad the roads were. Next time we go thru there, I am making my buddy drive his car
Old May 18, 2005 | 09:27 AM
pewterwest99
looks like you have your answer. Change the tires to be uniform and if the problem persists then look into suspension problems.
Best of luck
Old May 18, 2005 | 09:32 AM
pewterwest99
by the way, did it have all emt's when you first bought it and said it "felt glued to the road" ? or did you have the current tire set up at purchase time?
What about before you hit all those potholes? how did the car ride? same tire set up at that time?
Trouble shoot.
Old May 22, 2005 | 11:01 PM
Vogos97C5's Avatar
Vogos97C5
Yeah, when I got the car it had EMT's all the way around, and the car felt a lot better. I will probably change the tires in the front soon and match them to the back. I also have a slight vibration, shake in the steering wheel now after hitting the700 potholes up north. Yeah, I will do tires first, then start trouble shooting from there
Old May 23, 2005 | 12:01 AM
DBL001's Avatar
DBL001
well I agree the tires should be matched, but after hitting all those potholes get your front and rear alignment checked too
Old May 23, 2005 | 12:11 AM
Larry_Yerton's Avatar
Larry_Yerton
I would bet $ that's your problem. I had to "mix" for a few days until my new fronts came in and it handled like crap, it was all over the road.
Old May 23, 2005 | 12:31 AM
Swany00's Avatar
Swany00
Veteran: Marine Corps
I'm looking forward to getting rid of my EMT's, took 'er out for a spin yesterday and today and felt pretty rough on the road (nice switchbacks). CCW's should be here this week!
Old May 23, 2005 | 04:54 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
The mixed tires is probably the major culprit, but I have EMTs all around and when I first got the car it was also "glued to the road".
With wear of the EMTs, it seems to track the grooves in the road a lot more now. And, of course, I could have just gotten used to the car's handling. But wear seems to play a major part.
To handling issues
