Valve Stems
Old May 18, 2005 | 08:03 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Valve Stems
Does anyone know if the Sensor Valve stem takes a normal valve or a special one? Thought I read a thread where there were a couple different ones that are used or could be used.
Loosing about 3 pounds of air over 2 days and no punctures.
A little liquid soap at the end of the stem bubbles slightly so pretty sure it's the valve.
Thanks.
Old May 18, 2005 | 08:07 AM
ArmyVette's Avatar
ArmyVette
The value stem is an integral part of the tire pressure sensor -- they are one unit. I think it's pretty standard except that it's fused to the sensor.
If you're talking about the "plunger" that fits inside the value stem, I think that is pretty standard; it just screws in and out.
Old May 18, 2005 | 08:36 AM
Benpup's Avatar
Benpup
Yup, that's what I mean.
I certainly appreciate it.
I think it's time for a replacement on the "plunger"
Thanks ArmyVette.
Old May 18, 2005 | 08:49 AM
roscoe118's Avatar
roscoe118
I believe that you can replace the "o-rings" at the base of stem. I plan on doing this when I replace the OEM EMT's this summer.
I have read here that these can cause the type of air loss that you are experiencing. If the "plunger" doesn't fix it, then try the o-rings
Old May 18, 2005 | 08:56 AM
ArmyVette's Avatar
ArmyVette
Just thought of something else. Those little plungers can work loose. There's a very cheap tool that is used to remove and install them. Just tighten it up first and try to soap test. If it still leaks, then replace the plunger.
Old May 18, 2005 | 09:01 AM
Benpup's Avatar
Benpup
Got that tool and will do.
I'll also check the "O"- Rings
Appreciate it. God I love this Forum.
To Valve Stems
