headlight problem on 99 coupe
Old May 18, 2005 | 11:46 AM
mikalob27's Avatar
mikalob27
Default headlight problem on 99 coupe
when i turn on the light switch,sometimes it takes 10 seconds for them to pop up.and once when switching them from bright back to normal they just went out. does n e one else have this problem and know what it is or how to fix it?
Old May 18, 2005 | 06:44 PM
mikalob27's Avatar
mikalob27
Any ideas?
Old May 18, 2005 | 08:19 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Sounds like a headlight control module. I haven't actually experienced this but having just rebuilt my headlight motors I researched whether I should do the module at the same time. Use the search function and do a little research I think you'll agree. Good Luck!
Old May 20, 2005 | 01:06 PM
mikalob27's Avatar
mikalob27
thank you
Old May 20, 2005 | 07:20 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Your multi purpose light/turnsignal/dimmer switch has a broken wire in it. The next time you have this problem, move your tilt wheel up and down as you turn on the lights. I'll bet that the lights pop up right away.
The problem is that the wiring harness from the switch that runs down through the steering column gets bent/flexed each time you move the tilt wheel. After a time the wire(s) get broken.
Tom
To headlight problem on 99 coupe
