Help Driver Side Door Power Mirror Install
How do you reinstall this? I have tried compressing the spring that is held on by some type of washer to no avail, anyones help would be greatly appreciated.. It is currently taped on.. HELP!!!
1) Lower power window.
2) Remove door trim panel
3) Remove the door speaker assembly
4) Remove the mirror nut access plugs.
5) Disconnect the electrical connections
6) Disconnect the mirror harness from the retainers.
7) Remove the nuts from the mirror studs
8) Remove the mirror with the harness and gasket
Installation procedure
1) Position the mirror with the gasket and harness to the door
2) Install the nuts to the mirror. Tighten to 89 lb in.
3) Route the harness and secure the harness with harness retainers.
4) Connect electrical connections
5) Install the mirror nut access plugs
6) Install the door speaker assembly (22 lb in)
7) Connect speaker connections
8) Install Door trim panel.
http://forums.corvetteforum.com/show...8&page=1&pp=20
I guess I will find out just how handy I am, what a pain, I didn't realize the mirror was held on in such a fashion. Hopefully I will be able to get the inner door panel off without too much problem and I won't scratch up the mirror or car doing this procedure. I probably helped this mirror housing itself fall off, by not being extra careful when pulling the car cover off.
