LED Replacement for tail lights
Old May 20, 2005 | 08:22 AM
kg54trains's Avatar
kg54trains
Default LED Replacement for tail lights
Has anyone used a led replacement for tail lights. Advantage is less power needed, brighter light, star pattern in len, longer life bulb. They are a direct replacement as is the common replacement bulb.
If so,.. brand used and where purchased....
Old May 20, 2005 | 08:27 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Here you go:
http://forums.corvetteforum.com/show....php?t=1038826
Take a look at the Sticky at the top on Weights, Measurements, etc. Impeded in the post is a tremendous amont of info about the C5, including all or most of the relevant posts for LEDS.
Also take a look at the info posted by SpdKilz. He is something of the forum expert on LED's and has a webpage. CUlookin on the forum has also done quite a bit (I think) of LED mods.
