Fog Light Grille
Old May 20, 2005 | 12:07 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Default Fog Light Grille
Has anyone else out there seen this item? Very nice look, IMHO, and a unique mounting system.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old May 20, 2005 | 12:20 PM
Tom73's Avatar
Tom73
I like the looks of them but don't like them covering the fog lamps. Maybe if he put an opening to give the fog lamps a clear shot, the I might go for them.
tom...
Old May 20, 2005 | 01:50 PM
inospdn's Avatar
inospdn
I definitly agree ! After having to remove my Z06 grilles in order to pass Virginia State Inspection. I would be a lot more interested in these ,if the fog light was uncovered.
Old May 20, 2005 | 03:37 PM
timf1954's Avatar
timf1954
They appear to mount from the inside, which would be a PITA.
Old May 20, 2005 | 03:42 PM
2003vert's Avatar
2003vert
If they are like the ones from Ecklers and MA they just stick in with 2 side 3M tape I think the look great but like the ones from Ecklers better. My bad I did not read the the description. wonder how they do mount.
Old May 20, 2005 | 04:46 PM
BubblePuppy
I thought the same thing, so I asked just how these were mounted. His reply was:
"When I got my '03 I wanted to fill the empty spaces and did not like the look of the Z06 mesh screens so I made my own from the polished stainless steel. I am an unemployed engineer and have access to a machine shop where I make them all. Just trying to make ends meet for now. If you look inside the fog light opening, you will see a small tab on the top of the bumper fascia opening that has a slot in it. It is above and slightly outside of the fog light lens. I resistance weld on a small angle bracket with a hole in it and use a firtree fastener pushed into the slot. The grill is CNC machined and fits snugly in the interface between the fascia and the black plastic on the bottom. Because the top of the black plastic slopes downward the grill fits right in. I went through a couple of design changes until I made this style which works great."
Old May 20, 2005 | 05:05 PM
Not too bad looking, but I like the look of the original Z06 screens better. I just like the screens when the mount flush with the outer edge of the fog light area.
Old May 20, 2005 | 07:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Home depot gutter screen. Go get some, about $40 cheaper.
Old May 20, 2005 | 07:17 PM
Bullet's Avatar
Bullet
No shiot - looks very very similar to the gutter screen I saw at Lowe's last night.
(The gutter screen is used to keep stuff like leaves out of your guttering so that it doesn't get clogged up.)
Old May 20, 2005 | 07:42 PM
~SPEEDY~'s Avatar
~SPEEDY~
Old May 20, 2005 | 07:43 PM
Tom73's Avatar
Tom73
Never realized that gutter screen was made from 20 gage perforated 304 stainless steel
Old May 20, 2005 | 09:00 PM
C5naples's Avatar
C5naples
Would anyone here seriously put gutter screen from Home Depot on their car?
Old May 20, 2005 | 09:20 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Here are my screens I made.
Old May 20, 2005 | 09:24 PM
C5naples's Avatar
C5naples
Those are nice! Stainless?
Old May 21, 2005 | 09:58 AM
screw991le's Avatar
screw991le
Gutter screens is a term, this "screen" can be found in a roll, for heating and A/C fliters, gutters etc. They come stainless and painted and rubberized.
Its funny, I say Home Depot and people think it is a cheap rip off. You can get the screen at any hardware store. In any type (stainlees etc) It is just not pre-cut to the shape.
But excuse me for trying so save you 95% on a screen. Like the Key hole delete mod I posted awhile back that can be done for 45 cents and not 30 bucks like advertised.
But hey, its your money and IMHO.
Old May 21, 2005 | 02:25 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Hmmm. I don't know . They look okay, but I really like my Z06 screens and the way they really fill the space.
Old May 21, 2005 | 03:59 PM
Zilla's Avatar
Zilla
yep
To Fog Light Grille
Old May 22, 2005 | 09:17 PM
coast7's Avatar
coast7
Yes
Old May 22, 2005 | 09:41 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
[QUOTE=Zilla]Here are my screens I made.
Zilla,
What did you use for the rubber around the screen edge?
Old May 22, 2005 | 10:00 PM
Zilla's Avatar
Zilla
[QUOTE=lemansbleu2004]
Zilla,
I replaced the mesh in the OEM Z06 Screen with the stainless steel.
The plastic housing can be separated into 2 pieces then reattached afterwards. Here is a picture.
I was in the process of making a set of screen without the plastic housing and found that automotive door edge trim works wells.
