HELP with flush mount tail lights
Old May 20, 2005 | 01:33 PM
ALX99's Avatar
ALX99
Default HELP with flush mount tail lights
does anyone know how I can get info from a post on how to reset the flush mounts so they actually look flush????
thanks for your help....
Al
Old May 20, 2005 | 01:51 PM
wolfman04's Avatar
wolfman04
Someone had posted this some time ago.
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adheasive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Old May 20, 2005 | 02:13 PM
mike lalonde's Avatar
mike lalonde
7th Gear
Default flush tail light question
I purchased the kit from one of the vendors-installed as per the post of the member who did his own -at any rate the lenses are not even with the outside of the light opening-perhaps a quarter on an inch inset-but I really like the way the install went and the area stays much cleaner.
Old May 20, 2005 | 02:15 PM
BigJoe's Avatar
BigJoe
Hmmm cheaper than one of those kits... But are the spacers a standard hardware item? Would Home Depot or Lowes have them or would you need a hard core, old-time hardware store?
Old May 20, 2005 | 02:35 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
standard at Lowes where I bought them. I bought all 1 inch spacers and had to cut 1/4 inch off 2 of them to make them 3/4 inch. I then used the left over 1/4 inch pieces and added it to the 1 inch piece to make everything 100% flush.
Cutting the spacers was the hardest part of the job.
Old May 20, 2005 | 04:34 PM
BNLspeedaddict's Avatar
BNLspeedaddict
I bought this kit and thought it looked horrible. There were gaps between the lens and it looked budget. I would not recommend it
Old May 20, 2005 | 05:16 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Flush Tail Lights
Here is my set up:
http://www.cardomain.com/memberpage/273882/10
Old May 20, 2005 | 05:57 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
screw
1" spacers $4.77
1/4 Spacers $3.42
Hey...I resemble that remark!!!
Here is how they turned out...
Peace
Willfulone
__________________
..................Click for
To HELP with flush mount tail lights
