Cali emissions numbers?
I'm currently living in NYC, but I'm originally from the UK and maybe returning there at some point. If I buy a C5 here (probably modded), it'll need to pass UK emissions in order to get the car registered there.
The UK regs are:
CO 0.3% @ 2,000rpm
CO 0.5% @ Idle
HC 200ppm @ 2,000rpm
Can anyone give me equivalent numbers for CA? Having that would make it much easier for me to determine if a car would pass UK emissions regs because I could simply ask the owner or the tuner if the car would pass CA emissions.
Cheers,
Ian.
- HC: Max 128 PPM @ 15 MPH; Max 103 PPM @ 25 MPH
- CO: Max .80% @ 15 MPH; Max .60% @ 25 MPH
- NO: Max 1106 PPM @ 15 MPH; Max 936 PPM @ 25 MPH
So - it looks like the UK is a little more stringent on CO than California, and allows slightly higher levels of HC. Just FYI, I had a pretty highly-modded '85 up until last year, and it easily passed the sniffer test with 41/29 PPM on HC, .13%/.11% on CO, and 339/332 PPM on the NO. C5 should be much better than that.
