Opinions please
Old May 23, 2005 | 01:30 PM
VillainessC5's Avatar
VillainessC5
Default Opinions please
I brought my car to the dealer to get something repaired and they gave it back to me with both rocker panels damaged....driver side is really bad...big hole ripped in it...passenger side scratched up... Should I replace them or try to get it repaired???? The dealer won't take responsibility (of course) and the autobody shop said its a big job and $$$ to replace them totally. Any feedback greatly appreciated
Thanks!
~Shannon
Old May 23, 2005 | 01:39 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I just had my driver's side replaced ... it is a lot of work since it's one of the only of the panels that's glue on. It was about 1K est. from the insu. co.
Patching might be a < $ option, but it's up to you.
Next thing you should consider is getting rocker rails. They've saved me countless times.
Good luck. I hope it gets fixed soon to your liking.
Old May 23, 2005 | 01:44 PM
krabtree13's Avatar
krabtree13
apparently your "mechanics" do not know how to properly lift a 'vette!personally,i'd go right up the ladder to the service manager,general manger,owner;then,you might want to let them know that you'll be notifying the BBB,and/or the state attorney general's office of comsumer affairs.goo luck,shannon!
Old May 23, 2005 | 01:45 PM
EZ99B5's Avatar
EZ99B5
Thanks!
~Shannon
Let me see if I am understanding correctly. You took your car to the dealership and it was not damaged. You picked it up, it was damaged, and they aren't taing responsibility?
Old May 23, 2005 | 01:51 PM
Tim2K4Vert's Avatar
Tim2K4Vert
Personally, I'd be raising Hell! Those idiots messed up your car and don't want to admit it. Tell them that they need to replace the broken rocker panel and repaint the scratched one so that the car is exactly like it was when it came in. Otherwise, start talking to a lawyer. Good luck!
Old May 23, 2005 | 02:39 PM
VillainessC5
yup and its not the first time something like this has happened to me there... def. the last though
Old May 23, 2005 | 02:43 PM
VillainessC5
Already went to the owner, and he didn't care in the least and said i couldn't prove anything. ...nice way to treat someone that just bought a car from him, but it probably has something to do with me being a girl. but thanks I'll def. put a complaint into the BBB and and everything.
Stuff like this is just sooo frustrating as I'm sure everyone here knows
Old May 23, 2005 | 02:58 PM
DT's Avatar
DT
Howdy!
You need to escalate this up to a GM regional rep - you can probably score the name/number from calling GM directly.
I'd get some pics asap too - my dealer (who does an outstanding job, and really takes care of the car) has an area on their work orders to indicate any existing damage. If your work order has something along those lines, and nothing was documented, that will be good leverage as well.
You need a 3rd party (like a GM rep) to determine how the damage occured. It certanly sounds like a lifting issue as someone mentioned. I might even be inclined to take it to another dealer and just run the story past them, get their $0.02 (in my experience dealers don't seem to "stick together").
I'm also posting to TTT this - hopefully another owner in your area will see this, maybe someone from a big local club who has good contacts in the area.
Hope it works out - if they damaged the car, THEY should pay everything it takes to make it like is was before you dropped it off.
Old May 23, 2005 | 03:04 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Hi Villainess
That's so F'd up!!!
If I were you, I'd get Jason or your dad to go down there and raise hell about this!! They obviously didn't raise your FRC properly and crushed the rocker rails in the process. Hell, I'll go down there and get in their face for you! You'll have to talk to the general manager there or someone higher up and point out that the damage could have only been done by their lift. Threaten to take this to GM and to the BBB if you don't get any results.
The big problem with these a-holes is that they see a young female (or any female) and think they can get away with anything since they think females aren't car savvy and won't raise a stink if they screw up.
Someone posted up a GM complaint number before, I'll do a search for it but hopefully, someone will post it up if I can't find it.
Old May 23, 2005 | 03:17 PM
Alex1217's Avatar
Alex1217
Here's some important info I found including the number you can call to file a complaint through GM:
GM Contact Info:
Call the appropriate division's customer service phone number to register
a complaint or check recall information. Buick 800.521.7300;
Cadillac 800.458.8006; Chevrolet 800.222.1020; GMC 800.462.8782; Oldsmobile
800.442.6537; Pontiac 800.762.2737; Saturn 800.533.6000.
Better Business Bureau Info:
(BBB) Arbitration: GM contracts with BBB to arbitrate
requests for reimbursement of repairs, a GM "buy-back" of your vehicle,
or both. Call your local BBB or
800.955.5100 for arbitration hearing request forms or to file a complaint. For detailed advice,
the Lemon Book has a whole chapter on arbitration.
Small Claims Court:
Go to small claims for advice on
using small claims court to recover repair & other expenses. The Lemon
Book (Moyer-Bell 1990) by Ralph Nader has an entire chapter
on small claims court strategy, a state-by-state index & a chapter
on your legal rights to help you better argue your case in court. You
can order the book for $17.50 from CAS Publications.
Old May 23, 2005 | 03:26 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Everybody is under the impression that the BBB can actually help. Unfortunately they're almost completely worthless. It's actually just a company with a bunch of old farts running it, that have nothing to do with the federal government. It's more or less nothing more than an eBay sort of scoring system for companies that are paying members. I've been a member for 16 years and the only time I wanted to use them involving a suit, they couldn't do squat! What you need to do is IMMEDIATELY file a small claims suit. I'll bet the jerk will get you fixed up before his actual court date. Good luck to you. I'm very sorry to hear of your dilemma.
Richard
Old May 23, 2005 | 03:32 PM
99 TorchRed's Avatar
99 TorchRed
Thanks!
~Shannon
I can sympathize with your dilemma. I've been there too. Your auto is an extension of yourself once it's "doo-dadded" to your likes.
The dealer is responsible for damage done in their shop. A Corvette requires special lifting care and special lifting devices. The garage obviously did not have either in their service bay. If they couldn't service it properly you should have been told at the start, and you could have taken it elsewhere.
I would go to the dealer principal again and let him know that if he cannot resolve the issue, and the car is under warranty, that GM will be your next contact,.... and failing to have GM solve this issue, I'd weigh the cost of getting it repaired against the cost of hiring an attorney. If the repair is less, chalk it up to experience and get it fixed.
(From personal experience, I have found that the BBB doesn't do a whole lot when a complaint is filed with them.)
It pays to scout out the service area and the mechanics that will be working on your pride and joy long before you need them,... and that applies to tire shops too.
Good luck with the outcome !
Old May 23, 2005 | 03:34 PM
Alex1217's Avatar
Alex1217
What dealership was this BTW?? Maybe someone will chime in with experiences with that place.
Old May 23, 2005 | 03:36 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Now this really makes me ANGRY!!
There are a lot of women (not all of them,as we most certainly know )whom have wonderful dispositions,and do not enjoy contraversy.These types of women tend to just go with the flow...
These jerks thrive on this ,and the fact that your a woman( who doesn't know any better )....and it's just a way for them to deny their responsibility
DO NOT let them get away with this!
I suggest the nearest, car savvy, alpha- male to help you out in this matter.....they will get a much better reaction than you did!
Do not hesitate to go over their heads, as this is sometimes the only thing they will respond to.
If I were anywhere close, I would not hesitate to join you in a meeting...surely there is a forum member nearby whom can"talk" some sense into these guys...
If you have any recent car pics which show the previous condition, that would most certainly help your case....but regardless,your word should be sufficient..also, the tip above about existing marks on your car is good too
Good Luck to you, and keep us posted!
Old May 23, 2005 | 04:51 PM
VLVETTE's Avatar
VLVETTE
Taking pictures of the damage is a good call. The damage caused by incorrectly lifting as opposed to hitting something would be pretty evident. And what would a girl be doing trying to jack up a Corvette your honor?
Old May 23, 2005 | 08:41 PM
BostonJoel's Avatar
BostonJoel
Another sad story and an unfortunate victim. Keeps reinforcing my theory about NEVER taking a Corvette to a Chevy dealership under any circumstances.
Old May 23, 2005 | 08:47 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I would raise holy hell with these guys. Its bad enough they won't take responsibility, but damn, they are the selling dealership. File with the BBB, but thats not going to get your rockers fixed. I would let them know you're going to file an action in small claims court. May be a PIA and .....may not be successful but if they want to play hardball, then it doesn't hurt to threaten. I would also write a letter to the regional district manager for GM and let them know about the situation. Don;t 't let these guys off the hook..... Good Luck
To Opinions please
