Caliper bracket bolts
Old May 24, 2005 | 11:06 AM
Weprint's Avatar
Weprint
Default Caliper bracket bolts
I will be replacing warped brake rotors on my 2000 vert and noticed that GM specifies that the caliper bracket bolts cannot be re-used. Can these be purchased on line or do I have to go to the dealer? Are they something the dealer normally stocks? Does anyone have part numbers? Thanks for the help.
Old May 24, 2005 | 12:17 PM
yellow01's Avatar
yellow01
Most people reuse them, I did.
Maybe try gmpartsdirect.com. I just go to the dealer for this type of thing...but be prepared. They charge like crazy. $8 for two bolts for the lower shock mount
Old May 24, 2005 | 12:25 PM
Tim2K4Vert's Avatar
Tim2K4Vert
They can be re-used. You just need to clean them and put loctite on them when you put them back in.
Old May 24, 2005 | 12:42 PM
AE357's Avatar
AE357
Doing a rotor swap this week as well, called both local dealers parts depts. to get new bolts, both said not an item they stock? I asked off the record is that because everybody just reuses them and was told yepper.
Old May 24, 2005 | 12:47 PM
BNLspeedaddict's Avatar
BNLspeedaddict
I replaced my rotors two weeks ago, used lock tite but didn't clean the caliper bolts....now when im driving over a rough road, or hit any bumps it sounds like something is rattling..... I was going to take them apart this weekend and investigate. Maybe I need new caliper bolts?
Old May 24, 2005 | 01:24 PM
I've had the dealer reuse them before, but the last time I switched rotors I had them install all new ones. Went to the dealer and they of course had to order them. If you have a large dealer nearby, they may have them in stock.
Old May 24, 2005 | 01:32 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
What happens to them is they get metal fatigue. They're under a good bit of torque and after you've taken them off and on a number of times, the chances of them twisting or breaking increases. Naturally, you don't want something like that happening with your brakes.
But you don't need to change them every time you change your rotors. That advice wasn't made for people who change them as much as most of us do.
About every third change, I'd be looking for new bolts. Reusing them a couple of times is no big deal.
Old May 24, 2005 | 01:41 PM
BNLspeedaddict
good point, just ordered mine.....8 bucks each!
Old May 24, 2005 | 01:52 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Clean them up and put some red loctite and reuse them.
They wanted $8 a bolt so I saved $64 plus taxes
-Mike
Old May 24, 2005 | 04:45 PM
1KLRTOY's Avatar
1KLRTOY
-Mike
Old May 24, 2005 | 05:52 PM
diyguy's Avatar
diyguy
On another vehicle (NOT a vette), somehow the bottom bolt got cross threaded and stripped out completely.
HUM? Then what to do. - so drilled a hole through the head of the bolt and a hole on the cast mounting, then used aircraft 'safety wire' .032 ga, an did a real nice 'hold it in place' with stainless safety wire fix. Also put some red locktite on it.
That was 50,000 miles ago and not a single issue. The bolt has not budged. It's the shear strength of the bolt, not how much torque is on it - well to a degee, so that the bolt doesn't back out.
All the airplane guys will understand this - dumb, yes, but it works
To Caliper bracket bolts
