C5 max tire size
Old May 24, 2005 | 08:45 PM
2fast4sanity's Avatar
2fast4sanity
Default C5 max tire size
What are the widest tires i can run for front and for rear without worrying about rubbing or needing a mini tub? Ex: given an appropriately sized wheel, can I run 305, 315, 335. I know 295's will fit in the rear but how much wider can I go?
Old May 24, 2005 | 08:55 PM
pewterwest99's Avatar
pewterwest99
What size rims are you running? Stock C5, Zo6, or other?
Old May 24, 2005 | 08:58 PM
2fast4sanity
at the moment stock 5 spoke y2k wheels but I am looking at various aftermarket wheels. I am curious as to what size is the max possible; i can buy wheels to match.
Old May 24, 2005 | 09:12 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
on stock c5 wheels, i think many have run the z06 size tires as an upgrade.. 265/295
Old May 25, 2005 | 12:17 AM
2fast4sanity
is that the widest that can be run without modification?
Old May 25, 2005 | 01:48 AM
98stocker's Avatar
98stocker
i belive some are running the 18x12 zo6's with a 335 rubber without tubbing but if your going that wide without tubbing you have to worry bout the tire sticking of of the fenders....
Old May 25, 2005 | 10:08 PM
1badtrain's Avatar
1badtrain
My z06 is running an 11 inch rim with a 305-25-20. Sits flush with the fender.
Old May 25, 2005 | 10:45 PM
Cajundude's Avatar
Cajundude
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have 255s on the front and 295s on the back of my stock 02 Coupe
wheels without any problem.
Old May 27, 2005 | 12:19 PM
Johndirt's Avatar
Johndirt
Same question. I heard that a 335-30-18 rear wheel is possible, but the brake ducts pose the only real problem.
I also don't want to foul my geometry, or end up with a straight line (only)driver. Surely you track guys have my answer. I'll buy the brew for good advice!
I want trackability, and stickyness to handle my new (517)ponies, but won't tolerate ANY rubbing, nor tubbing.
Please help!!!
JD
Old May 27, 2005 | 12:56 PM
shurite44's Avatar
shurite44
Old May 27, 2005 | 04:46 PM
FKING1's Avatar
FKING1
Saw a ZO6 last night with this combo and no rubbing.
Fred
Old May 28, 2005 | 12:47 AM
91VetteOkc's Avatar
91VetteOkc
I have 335 30 18 on the rear with 11.5" Z06 rims with no problem. Not many tire choices though. The tire does roll over the edge of the rim a little but looks good. Found a good deal on 295 35 18 comp ta and will try them next.
Old Jul 30, 2018 | 06:41 PM
907Z06's Avatar
907Z06
Default Offset?
Hello 1badtrain, would appreciate if you could pass along what offset your wheels are?
Old Jul 30, 2018 | 07:33 PM
Boeuf's Avatar
Boeuf
Not sure if you realized but that post was from 13 years ago.
You may not get a response.
Old Jul 30, 2018 | 08:00 PM
grantv's Avatar
grantv
The guy he asked.. hasn't posted in 5 years.
Old Aug 1, 2018 | 03:50 AM
907Z06's Avatar
907Z06
Ha, what’s 13 years, feels like yesterday! Thanks, and no I did not pay attention to the post date. Heck my Z06 is 15 years old, doesn’t feel like I have had it that long, and only 30k on the odometer, just figured it was time for new shoes. Least I’m not the only one surfin old posts,,,lol
Old Aug 1, 2018 | 11:30 PM
oneandgone's Avatar
oneandgone
If you'd not have searched and just posted the question they'd have beat you up for that. lol I think a 315 is as wide as you'll get without much poke, but other don't seem to mind if the tire hangs out like it's the 70s. Guess it depends what you're into.
To C5 max tire size
Old Aug 3, 2018 | 01:39 AM
striper's Avatar
striper
I'm running 305/30-19's on 19x11 rears, no rubbing but I wouldn't go wider. Sticks out slightly. I'm running 265/30-19's in front on 19x9.5. Could have used a wider tire, maybe a 275, but I like the sidewall height combination visually.
Old Aug 8, 2018 | 08:10 PM
907Z06's Avatar
907Z06
Thanks Striper, not to be a nuisance, do you know the offset as well?
Old Aug 8, 2018 | 10:42 PM
fuggles's Avatar
fuggles
305 on the rear fits with stock z06 rims. no poke. 315 will also fit, but sticks out a bit. no rubbing though. I've had both on my z06 with the stock rims.
