Will acrylic tops shatter?
Old May 25, 2005 | 07:33 AM
Railfan's Avatar
Railfan
Default Will acrylic tops shatter?
I was recently warned that I should remove my acrylic top on my coupe before jacking it up, do to flexing of the car. If left on, I was told that the top could crack, or even shatter. Any truth to this?
Old May 25, 2005 | 07:47 AM
ArmyVette's Avatar
ArmyVette
This is an old wives tale. The structure of the Vette is strong enough that you do NOT have to worry about this issue.
Verts and coupes have the same chassis; no problem ever jacking up the Vert. Think about it. You've got a roll bar build into the frame on your coupe. No flexing there!
Old May 25, 2005 | 07:58 AM
JLA's Avatar
JLA
Mine was up/down/up/down 2 weekends in a row. Never took the top off. -0- prob's.
Old May 25, 2005 | 01:19 PM
Had my car up on a jack many, many times in the four + years I have had it and almost always with the top latched on. No problems with cracking, etc. so far.
Old May 25, 2005 | 01:25 PM
British's Avatar
British
If your car was going to flex that bad from jacking it up, I'd think the top would be the least of your worries!
Old May 25, 2005 | 01:40 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I had a 63 SW and I was told that wen jacking to open the doors and the hood as the FG was straight line bonded (top of fenders etc.)
Some I saw did crack at the joints, but the new ones are "not to worry."
Old May 25, 2005 | 01:43 PM
cadams's Avatar
cadams
i doubt thats its acrylic anyway...isn't polycarbonate or something?
nonetheless, both materials flex nicely, but like all above said, there shouldn't be any torque on the top when on the lift
Old May 25, 2005 | 02:28 PM
HummelS's Avatar
HummelS
It's certainly true that you don't need to do this with the C5, but my C4 body-colored roof panel had a stress crack because the roof wasn't removed when it was jacked. So, it's an old wives tale with some historical precedent.
Old May 25, 2005 | 02:40 PM
Face's Avatar
Face
You can drop a C5's roof from 30 feet in the air and it won't shatter. Don't ask me how I know this.
To Will acrylic tops shatter?
