What is wrong???
May 26, 2005 | 05:30 PM
What is wrong???
The lights on the dash while driving would dim (not go out)...it is more apparent at night. The dimming is for a short time....less than five seconds. Is there a ground or short problem somewhere?
Help!
May 26, 2005 | 05:32 PM
Bad Ground, bad alternator or your battery is dieing would be my guess....good luck.
May 26, 2005 | 05:33 PM
Check the battery first.
May 26, 2005 | 05:40 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Quote:
And by check it, look under it. If it's leaking, you may not see it from the top.
EDIT:::: If you wanna check the grounds ...hope this helps.
May 26, 2005 | 06:04 PM
Thank you very much. That is the most detailed help yet....
I will check the battery first though.
May 26, 2005 | 06:22 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Happened to mine right after I bought it. The positive battery cable was loose. Hope your problem is that simple
