Underhood Light Question
Old May 26, 2005 | 08:26 PM
BillW's Avatar
BillW
Default Underhood Light Question
OK. I'm an idiot. The underhood light isn't working on my 03. I took the bulb out to check the filament (which isn't broken). For the life of me I can't get the bulb back in correctly. Any tips? (I suppose I'll check the fuse next. At least I can take them out and put them back in. Thanks.
Old May 26, 2005 | 08:29 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Don't feel bad ...
Just put one end in ... then take a flat, PLASTIC item and push the other connector in just enough to put the second end of the bulb over it. I did mine with a screw driver, but be careful you don't end up looking like Buckwheat
BTW, the light doesn't work at all, or did it turn off 'cause you had the hood up for a while. There is a power saving mode on that light.
And check the wire connection near the front of the hood ... to the right of the airfilter.
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Check to see if the wiring harness is plugged in. When I bought mine, for some odd reason, the harness was un done and the bulb was blown too.
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Take 3 or 4 of the plugs off that hold the hood liner. My wiring harness was unplugged. I'm willing to wager that's your problem.
Let us know.
Old May 26, 2005 | 08:38 PM
BillW's Avatar
BillW
Thanks for the quick replies. I'll let you know how I make out.
Old May 26, 2005 | 08:47 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Yeah, mine was unplugged as well. I followed the wires down and saw it was unplugged, plugged it in and presto it works. But now I've noticed it's not working I'll have to check it out and see what it is now.
Old Jun 5, 2005 | 12:09 AM
SteveGel's Avatar
SteveGel
Hi, this is my first post. I have a 2001 z06 and having the same problem. I put my voltmeter and got 10v and the light is good. but it will not turn on?
unless it needs 12 volts? hmm....
Old Jun 5, 2005 | 12:23 AM
rickko's Avatar
rickko
I was just going to suggest BillW take a voltmeter to his recepticle and check the voltage (just after opening the hood so it doesn't time out).
Yep, 10v just isn't going to get that 12v bulb going. Check voltage at plug near radiator. Hope its 12v there.
..rickko..
Old Jun 5, 2005 | 02:07 AM
SteveGel's Avatar
SteveGel
..rickko..
Thanks rickko , I just did what you said. I check the plug had 12 volts and it look like it had dry water green stuff in it. Clean it out with q-tips and I bended the prongs just alittle and my light came on. If it start's acting up again...i'm going to get a new plug at a computer store and wire it in.
thanks for the tip.
Old Jun 5, 2005 | 07:00 AM
Live2shift's Avatar
Live2shift
Cruising
Default What the Heck!
Great Post Guys!! I have been wondering what the heck was the issue with my lite. Unplugged connector for me as well. WTF! IS this a factory issue, or just mechanics unplugging this for some reason? Jeff
Old Jun 5, 2005 | 07:14 AM
csexton's Avatar
csexton
Sometimes mechanics do forget to plug them back up!
To Underhood Light Question
