Alarm Question
Old May 28, 2005 | 09:30 PM
LS7's Avatar
LS7
Default Alarm Question
I just replaced the batteries in both of my remotes and did a keyfob relearn for both according to the 2000' manual.
Now, every time I am near the Vette the car horn honks whether I locked the doors to set the alarm or if I didn't set the alrm.
What's the deal with that? Everything still works as far as the alarm goes, it's just really annoying.
Old May 28, 2005 | 09:58 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
both remotes work?
car battery low?
any message on dic
Old May 28, 2005 | 10:24 PM
LS7's Avatar
LS7
Battery is Optima Redtop and is good
Both keyfobs work
No codes on DIC
Old May 29, 2005 | 12:35 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Sounds like you've got the passive entry activated. I don't know exactly how it works but if you check the tech tips or do a search you'll probably find info.
Other suggestion would be to check all the grounds.
Old May 29, 2005 | 09:05 AM
LS7's Avatar
LS7
My Bad.
I had the Passive switch on the remote activated.
To Alarm Question
