Help check engine light
Old May 29, 2005 | 01:21 PM
baddvette98's Avatar
baddvette98
Default Help check engine light
I'm having the same problem I had about 2mon ago. Cyl. #7 has a misfire last time this happened I put a new coil, plugs and wires and that did not fix it. So I took it to the dealer and they put a new computer in it and it fix the problem until now. What could it be? At a steady speed it misfirers bad, but when you are in the throttle its fine.
PLEASE HELP!!
