Anyone ever buy a Dash Pad?
Old May 29, 2005 | 06:41 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Default Anyone ever buy a Dash Pad?
Just curious.
How much do they go for (w/HUD)
Old May 29, 2005 | 06:45 PM
JLA's Avatar
JLA
No offense, but they are hideous. They started making them because people had 12 year old cars that they wanted to "mod."
Old May 29, 2005 | 06:48 PM
Flying Ace's Avatar
Flying Ace
Oops, I guess I meant to say..
"has anyone ever replaced their dash?". I'm putting a HUD in my 2000 coupe and am considering buying a dash with the HUD cutout (factory).
I just don't know what a good price is.
Old May 30, 2005 | 10:27 AM
jerrymcb's Avatar
jerrymcb
All you need is the trim piece. You can cut your existing dash.
Old May 30, 2005 | 10:41 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I just installed a HUD in my 2000. Your dash can easily be cutout to accomdate the projector, then all you'll need is the dash bezel, which is fairly inexpensive. If you still want to go the new dash route, post a WTB on the C5 Parts for Sale forum or contact Gene at Gene's Kar Shop, supporting vendor and excellent to work with. I've seen prices from $150.00 and up.
Old May 30, 2005 | 01:25 PM
Flying Ace's Avatar
Flying Ace
Thanks for the info! I'm probably buying the stuff from Fred Beans. Do you know if the HUD or the Switch come with the 11 pin harness?? I'm trying to get my hands on one.
Also.. How did you cut your dash?
Thanks.
Old May 30, 2005 | 02:10 PM
PaceThis's Avatar
PaceThis
THe dash is going to be very expensive new...use a router or a scroll saw to cut yours out and save the money...or buy a used one.
You can NOT order the 11 pin harness you'll need...not new anyway.
Old May 30, 2005 | 04:59 PM
VetteDawg's Avatar
VetteDawg
Hi. I used this page as my guide.
http://joshker99.home.comcast.net/hudinstall2.htm
The only thing I did differently was to cut the legs of the trim bezel shorter and use screws and washers instead of the glue.
The 11 pin harness remains a problem...unless Josh still makes and sells them.
...and I used a dremmell tool for cutting the dash and the "L" attatchment for drilling the hole for the projector.
...and while you're at it, might as well paint the gauge bezels in the cluster.
Good Luck!
Old May 30, 2005 | 06:35 PM
Flying Ace's Avatar
Flying Ace
VetteDawg,
Great info!
Thanks!
Old May 30, 2005 | 06:50 PM
rob&dalevance's Avatar
rob&dalevance
Save your money and cut your dash, it isnt as intimidating as you think, and also you will prabably do a better job than factory. I have noticed a lot of factory HUD's are cut too far and the bezel does not hide it all. Just like PaceThis said, use a rotory tool.
To Anyone ever buy a Dash Pad?
