How Do You Remove Air Bridge Fasteners?
Old May 30, 2005 | 03:22 PM
Dave1998's Avatar
Dave1998
Default How Do You Remove Air Bridge Fasteners?
I am looking to change the air box on my 98. These 2 fasteners look to be rubber. Do you pry them off? My other question is: I see there is rubber like washer below the plastic air bridge ears. Do you pry betwen the bridge and the rubber washer under the bridge or do you pry below everything ?
Old May 30, 2005 | 03:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Pry up the little push-pin in the center of the fastener with a small screwdriver. That is a seperate insert that expands the whole fastener to lock it in place. Once that is out, the whole thing will easily pull out.
There are numerous pins of this type used throughout the car.
Old May 30, 2005 | 04:17 PM
Dave1998's Avatar
Dave1998
Default Air Bridge
Tom
Thanks for the tip. I never would have spotted that small pin
Dave
Old May 30, 2005 | 04:20 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by Dave1998
Tom
Dave
Don't be timid about using a little pressue in getting it dislodged. SOme can be a bit stubborn to pop.
To How Do You Remove Air Bridge Fasteners?
