Problem with washer fluid running UP windshield!
Old May 30, 2005 | 08:05 PM
JTAllen79's Avatar
JTAllen79
Default Problem with washer fluid running UP windshield!
What is the fix for windshield washer fluid drooling UP the windshield on the drivers side during hard acceleration? I saw something about this sometime back and tried a search with no luck. Thanks.
Old May 30, 2005 | 08:20 PM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
Drive slower?
Old May 30, 2005 | 08:25 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
I have never had this happen. Seems to me for this to happen there has to be a crack in the hose between the pump and nozzle. Once air gets into the hose the fluid could seep out.
Strange one Good luck tracking it down.
Old May 30, 2005 | 08:36 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
take some of the fluid out - it only does it if its full. There are some check valves you can splice in too, but leaving it at around 3/4 full works fine...
Old May 30, 2005 | 08:40 PM
Shylor's Avatar
Shylor
Known issue and covered under warranty.
I have the same problem and debated over taking my car into the dealership for it. I would rather not let those service department idiots touch my car, so I may just pay for the part and install it myself.
Old May 30, 2005 | 08:57 PM
JTAllen79's Avatar
JTAllen79
I'll remove some more of the fluid and try that. I topped it up before the Florida run but never used any.... I had heard about the check valve and the dealer thing is completely out of the question.
Old May 30, 2005 | 09:35 PM
Freestyler's Avatar
Freestyler
is the "rain-x bug remover (windshield washer fluid)" any good to use by the way?
Old May 30, 2005 | 09:47 PM
Don't fill the tank so full. There is also a check valve that you can buy (I think from Ford) that will stop the fluid from coming out.
Old May 30, 2005 | 09:53 PM
4deatr's Avatar
4deatr
Mine did the samething and it is a ford check valve.
I do not have the pt number but if you call them they can help you. Just don't drive the vette
Old May 30, 2005 | 10:01 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
GM part number 22102237
Old May 31, 2005 | 12:05 AM
VLVETTE's Avatar
VLVETTE
Old May 31, 2005 | 04:07 AM
Shylor's Avatar
Shylor
Again....GM has its own valve so there is no need to use the Ford part. And it is covered under warranty, for those that are interesed.
Old May 31, 2005 | 06:49 AM
Dark-Knight's Avatar
Dark-Knight
There is a check valve to stop the weeping of washer fluid under hard acceleration. Had mine fixed last week as part of other minor warranty work.
Always a bit of a pisser to have a spotless car get water streaks on clean windscreen...
Old May 31, 2005 | 09:54 AM
vetdude's Avatar
vetdude
Old May 31, 2005 | 06:24 PM
Shylor's Avatar
Shylor
Don't you love how some keep posing the same answer about the valve, when this information was already posted yesterday.
To Problem with washer fluid running UP windshield!
