Jack Points
Old May 31, 2005 | 10:34 AM
fi9aly's Avatar
fi9aly
Default Jack Points
99 coupe(targa) automatic.
Question: In the owners manual is shown the jacking points. I have noticed in several suppliers magazines, plastic and metal inserts that go into a slot that is supposed to be on the corners of the frame. If so, where are they located, and are these inserts safe. Preparing to change brakes and rotors. Thanks in advance.
Ken
Old May 31, 2005 | 10:40 AM
RCK1999's Avatar
RCK1999
Ken
Look in front of the back wheels and behind the front wheels. Note that the rocker panels curve under the car. There are 2 "cut-out" areas on the rocker panels with slots in them on each side of the car. The inserts that you speak of are spacers to allow a jack to be used in these cut-out areas and not rest on the rocker panels. Lots of folks use a hockey puck as a spacer.
Old May 31, 2005 | 12:25 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Question: I have noticed in several suppliers magazines, plastic and metal inserts that go into a slot that is supposed to be on the corners of the frame. If so, where are they located,
Ken
Here is a picture of their location.
Hope this helps!
Jeff
Old May 31, 2005 | 01:05 PM
wit2pz's Avatar
wit2pz
Hey, fi9aly, I bought a set of hockey pucks at Dicks sport shop, and they work great. I had to show the guys at a Good Year shop in Ohio how to use them because they had to jack up the car for an oil change. The car has 4 slots where it can be jacked up from without damage to the body.
I changed my rotors/pads with them and a decent jack and 4 stands I got from Pep Boys. Good luck!
Old May 31, 2005 | 01:28 PM
TOPGUN9's Avatar
TOPGUN9
Where did you put the jackstands?
Old May 31, 2005 | 03:51 PM
wit2pz's Avatar
wit2pz
I put the jackstands on the crossmember just inside the jacking points. Some noises, but worked like a charm. I'd never had the car up off all 4 corners before, but the stands did well.
Chock the wheels before raising/lowering, minimum 1 corner, front and back!
Old Jun 1, 2005 | 10:07 AM
fi9aly's Avatar
fi9aly
Default Jack points
Thanks for all the help and advice. Question: Wonder why these are not in owners manual?(if they are I missed them)
Old Jun 1, 2005 | 10:25 AM
RCK1999's Avatar
RCK1999
I agree. Chevrolet could promote them in the owner's manual and stock them through their parts counter at $500 per set!
To Jack Points
