Alignment after lowering?
Old May 31, 2005 | 04:19 PM
MiamiCowboy's Avatar
MiamiCowboy
Default Alignment after lowering?
Is it necessary to have the axles aligned after you lower the car on the bolts?
Old May 31, 2005 | 04:26 PM
BNLspeedaddict's Avatar
BNLspeedaddict
I didn't get mine aligned after and it runs very straight.
Old May 31, 2005 | 04:31 PM
Patches's Avatar
Patches
It's always a good idea to have a 4-wheel alignment after lowering it. The factory alignment is not always spot-on and if it was marginal before lowering, it could be significantly off after.
Old May 31, 2005 | 04:37 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I bought my car BN last year. It has never hit a pothole or anything like that. The front tires feathered on the insides pretty bad last year (10K+ miles). Last winter I lowered the car on stock bolts. Since I brought the car back out I have called 3 different alignment shops that have been recommended to me by fellow Vette owners. All want the car for the day and will not let me wait. I call . In all my years I've never had anyone want any of my lesser cars or trucks for the day. If I can't wait, they can't be trusted by me. All that said, I've put a few thousand miles on this year and the tires seem to actually be wearing better than last year.
Old May 31, 2005 | 04:40 PM
MiamiCowboy
Thank you for the feedback.
Old May 31, 2005 | 04:49 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
FWIW- I saw that Patches posted while I was slowly typing. As a newbie I should let you know that he knows 1,000,000,000,000,000 times more than me.
Old May 31, 2005 | 04:50 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Old May 31, 2005 | 05:01 PM
Patches's Avatar
Patches
Not true and I'll even post to the contrary of what I said. Mine was pretty close even after lowering but I've had buddies whose cars were way off after they lowered theirs'. It's not worth rolling the dice on an expensive set of tires for the price of an alignment though, IMHO.
Old May 31, 2005 | 05:59 PM
leaftye's Avatar
leaftye
The (static??) camber and toe changes when you lower the suspension. Those changes may be for better, worse or a mix of both.
Old May 31, 2005 | 08:18 PM
T_Vert's Avatar
T_Vert
i had lots of neg. camber in the rear after lowering.
Dave
Old May 31, 2005 | 08:35 PM
1KLRTOY's Avatar
1KLRTOY
YES
Old May 31, 2005 | 08:56 PM
binkysgarage's Avatar
binkysgarage
Lowered mine on stock bolts, had too much camber and toe was off making the car fallow cracks in the road and was bad in the truck ruts.
Old May 31, 2005 | 09:52 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I think it is a good idea for several reasons.
1. The alignment changes when you lower the car. Lowering causes the following changes:
- Front and rear camber goes more negative when you lower the car.
- Front goes more toe in, rear more toe out (due to the placement of the tie rods).
2. The stock concentric bolts are notorious for moving and when they move the alignment changes a lot. So periodic checks are probably wise. I actually mark mine with finger nail polish so I can tell quickly after each track session if they have moved and just as quickly put them back to the right spot without my alignment stuff.
As another note on alignments, the stock specs have a very wide tolerance, so I would talk over your alignment with your shop. For example, the front camber spec for the Z06 is -0.7 +/- 0.5, meaning anything from -0.2 to -1.2 is "in" spec. That is a huge range. There is a cross camber spec if +/- 0.25, but still that means your shop can put the front camber at -0.2 LF and -0.2 RF or -1.2 LF and -1.2 LF and both meet the manufacturers requirements.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 31, 2005 | 09:54 PM
3318C5's Avatar
3318C5
Old May 31, 2005 | 10:50 PM
SPD KILZ's Avatar
SPD KILZ
Lowered mine and wore the inside of my front tires out within 4000 miles! Got it fixed before the new set went on. O and they still couldnt get it perfect....
Old Jun 1, 2005 | 05:57 AM
FiberglassFan's Avatar
FiberglassFan
This is how you set them up for autocross or road racing...more negative camber, slight toe in on the rear, toe out on the front. If you have runflats, static camber needs to be zero, due to ultra stiff sidewalls not compliant enough to deal with any camber....I won't run runflats for lots of reasons, this is just one.
Setting front toe to zero, or vert slight toe-in will cure darting, and if you don't have runflats, a little neg camber .5 degree, is good for cornering traction.
Old Jun 1, 2005 | 06:28 AM
ooh yeah's Avatar
ooh yeah
I'm taking my car in this friday, sometimes I auto-x but not often. I do run run flats when not auto-xing, so what should I tell the dealer I want? I lowered the car 1 inch plus I'm running Bilstien shocks. Thanks
Old Jun 1, 2005 | 06:44 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I lowered mine on stock bolts at about 7000 miles and now with 21000 miles on it (without realignment) there is no evidence of any abnormal tire wear (Jeeez I wish these run-craps would wear out! ) and no abnormal handling characteristics.
To Alignment after lowering?
