Help Please
Old May 31, 2005 | 06:50 PM
Tim downs's Avatar
Tim downs
Cruising
Default Help Please
I have a problem that I need the forum's help with. I have a 1999 vette and the dash lights, and the rear running lights are out along with cruise control. The dash lights up properly with twilight sent. As per this forum I changed the flasher unit behind the warning button( the instructions worked perfectly. I turned on the lights and the dash worked for a second and then I think the flasher unit blew because I have the same problem again. I turned on twilight sent and the dash , fog lights came on. I noticed that one of my foglights is out, probably before I switched the flasher unit. Do you think that a blown foglight could blow the flasher unit. Can I find the short if there is one without buying and blowing another flasher unit. Any help would be wonderful. I also can not seem to get competition mode to work?
Old May 31, 2005 | 08:53 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Ttt
