For those with 04's
Old Jun 1, 2005 | 12:12 PM
Rattler71's Avatar
Rattler71
Default For those with 04's(update)
For the last couple of months my 04 Z has had this musty smell that would come and go. I suspected water was getting in somewhere but could not find it. Last month I installed insulation in the trunk area to help cut down noise. The musty smell got so bad last week that I took the car to the dealer. What they found was unbelievable. In the bottom of each storage compartment were holes that were left by the factory when the panels were pulled from the machine that made them. So all this time, every time I would drive in the rain, the storage compartments were becoming soaked. The water would drain back out the holes they came in. When I put the insulation in, it was trapping the water and causing the smell in the carpets. They say it will take about 2 days to fix and clean/replace the carpets. Mechanic said this was the 4th '04 vette he has seen with this problem.
Scott
Old Jun 1, 2005 | 12:19 PM
Hot BluZ's Avatar
Hot BluZ
From: The problem with socialism is eventually the government runs out of other people's money
Thanks for the info, haven't driven in rain yet, but here in FL the likelyhood is high. I'll check it out to make sure I don't have the holes and if so cover them up..Hope things dry out good, make sure you don't get any mold in the carpet to cause health issues.
Old Jun 1, 2005 | 12:33 PM
DaBoz's Avatar
DaBoz
now that suxs.... I'm getting ready to sound proof my hatch area so thanks for the heads up!
Old Jun 1, 2005 | 12:38 PM
Rattler71's Avatar
Rattler71
DaBoz, that is the scariest avatar I have seen.
Scott
Old Jun 1, 2005 | 12:43 PM
DaBoz's Avatar
DaBoz
Scott
Scary????? You mean sweet little MJ?????
Old Jun 1, 2005 | 12:45 PM
Darion's Avatar
Darion
Thanks for the tip, I will be checking that tonight.
Old Jun 1, 2005 | 12:58 PM
Rattler71's Avatar
Rattler71
The holes are located at the very bottom of the storage compartments. There is some machine grooving around them. Mine had 2 in the center compartment and one each in the 2 side compartments.
Scott
Old Jun 1, 2005 | 01:03 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Scott
I have craving for Jesus Juice now ....
Quality control at GM ...
Old Jun 1, 2005 | 02:26 PM
Rattler71's Avatar
Rattler71
How would you know if there is mold. After cleaning, if mold is still there, would you smell it? I already told them if it still has that musty smell, I would not accept the car like that.
Scott
Old Jun 1, 2005 | 04:21 PM
Tim2K4Vert's Avatar
Tim2K4Vert
I haven't had that problem with mine yet although it hasn't seen a lot of rain. Can you see the holes from underneath the car? I know that my '00 Vette had a musty smell sometimes, especially when I ran the AC.
Old Jun 1, 2005 | 05:28 PM
wolfmd's Avatar
wolfmd
Thankfully I didn't have that problem on my '04, even though this was one of the wettest years in S. California history. Regardless, thanks for sharing the information so that others can be aware.
Old Jun 1, 2005 | 05:51 PM
TruUndrtkr's Avatar
TruUndrtkr
haven't smelled any must in my vette..thanks for the alert though
Old Jun 1, 2005 | 06:09 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
Thats the funniest thing I have seen all week! Thanks for the laugh!
AZC5
Old Jun 1, 2005 | 06:10 PM
TruUndrtkr's Avatar
TruUndrtkr
AZC5
that's dave in the middle..
Old Jun 1, 2005 | 06:28 PM
Rattler71's Avatar
Rattler71
I am sure you can see the holes from the bottom. I could see the pavement below in mine.
Old Jun 1, 2005 | 07:49 PM
Mr.Z-06's Avatar
Mr.Z-06
Default Thanks so much Rattler!
Thanks for the good advice Rattler. Just came home and checked my '04 Z. Sure enough, one in the center and one on each side (though I don't think the side ones actually went all the way through, but I couldn't tell).
Got a nice black oem-style plug for the center one with clear silicone for protection, and siliconed the side ones as well. Took about 5 minutes total.
It's really overkill with my car because it will never see rain, but on the off-chance I get caught, at least I won't have soaked carpets to dry out along with a full detailing job to do!
Thanks again!!! Great info.
-Mr.Z-06
Old Jun 1, 2005 | 08:58 PM
Raced Guy's Avatar
Raced Guy
My 99 FRC the front carpet on both sides gets wet when it rains or when it goes through a high pressure wash. Any ideas, this is really really bugging me and i cant find the problem ???
To For those with 04's
Old Jun 2, 2005 | 12:29 AM
DaBoz's Avatar
DaBoz
OK.... just finished my sound proofing and sure enough, center one had a small hole. As said above, I could see all the way through. The side compartments had holes but I couldn't get a probe to go through.
Small hole, may be 3/16's.... don't see how very much water could get in there. But, you never know....
Old Jun 2, 2005 | 06:52 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Thanks for the heads up on this I will check mine today and post what i find.
Old Jun 2, 2005 | 09:25 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Not sure, but this (holes on the storage compartments 'bottoms') many be common to other years.
My '99 has them, as did my '97, '98, '00 & '01. I believe these were OEM 'desired' to allow exit of fluids from the trunk areas (should someone spill something is my take on the reason).
When doing MikeMercury's insullation process I covered them. In no cases have I had any issues (I.e., musty smell) with that process accomplished.
I do not carry anything liquid in the trunk, so I believe I am safe from the OEM original reasons for these holes.
