Sprak plug wire shields?
Old Jun 1, 2005 | 04:19 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Default Spark plug wire shields?
I just installed my new MSD wires. I did not put the factory shields over the wires...should I have done this? They will fit, but not as well as with the original stock wires.
Old Jun 1, 2005 | 04:35 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Don't know what a Sprak is, but I believe a lot of the members get rid of the shields once they change plugs, but don't quote me.
I'd like to know too as I'm due for a change.
What plugs are you using?
Old Jun 1, 2005 | 04:39 PM
DidntSettle
I don't know what a sprak is either....operator error! I'm using NGK TR55's.
Old Jun 1, 2005 | 04:41 PM
Benpup's Avatar
Benpup
Thanks. I'll see what I can find out regarding the heat guards. I know there were previous posts regarding them.
Old Jun 1, 2005 | 04:54 PM
DidntSettle
I just did a search on this and it seems that some folks are complaining about MSD wires melting? Is this a common issue with the MSD's? I guess I will put the heat shields on over the new wires.
Old Jun 1, 2005 | 05:02 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Your best bet is to buy a set of Cool Sox. They are far superior to the stock plus, if you have headers they are a must have.
Old Jun 1, 2005 | 05:07 PM
DidntSettle
Can you give me a source? Thanks.
Old Jun 1, 2005 | 05:32 PM
123Gone's Avatar
123Gone
I'm considering LGM's wires that have a heat resistant sleeve built into the wires.
http://www.lgmotorsports.com/shop/pr...8423c3768354cc
BTW, the site states 8 mm, but they are actually 8.5 mm.
Old Jun 1, 2005 | 05:58 PM
123Gone's Avatar
123Gone
Found a link to Koolsox.
http://www.koolmat.com/street.shtml
Old Jun 1, 2005 | 06:01 PM
DidntSettle
Thanks!
Old Jun 1, 2005 | 06:04 PM
rob&dalevance's Avatar
rob&dalevance
I have had the MSD's w/o cool socks or anything for about 15,000 miles and have no sign of any melting. I also have LG Lontubes, so mine is a little warmer than stock... That melting issue may be a myth.. Someone contact mythbusters and get this taken care of!!
Old Jun 1, 2005 | 06:26 PM
blazin272's Avatar
blazin272
I used cool sox on my new plugs and wires too. Works awesome, little tricky gettin' 'em to fit all the way down, but, worth it. IMHO
Old Jun 1, 2005 | 06:40 PM
Lancer033's Avatar
Lancer033
I put them back on with my MSD wires, doubt it'd be a problem unless it gets really hot, but it shouldn't be hard to put them on, just pull the plug and slip it on.
To Sprak plug wire shields?
